Spectre intake question
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By ChurchSTSV
Cadillac STS-V Series Forum Discussion, Spectre intake question in Cadillac V-Series Forums; Out of all those of you who have trimmed the engine panel to fit over the intake, can you post ...
    ChurchSTSV's Avatar
    ChurchSTSV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V
    Oct 2012
    Chandler,AZ
    33
    369
    Out of all those of you who have trimmed the engine panel to fit over the intake, can you post a picture? I want to trim mine because it doesn't really fit anywhere in my garage.
    baller95 likes this.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Re: Spectre intake question
    Do a Google search for it I posted instructions and pics when we developed it. I even gave measurements of how much to cut. Shoot me your email addy. I am pretty sure I still have the pics with measurements.
    ChurchSTSV's Avatar
    Oct 2012
    Chandler,AZ
    33
    369
    PM Sent
    Rboughne1's Avatar
    Rboughne1 is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-V: CAI, HE, 2.4" Upper, TB & S/C Port, Headers, Exh
    Jul 2014
    Jersey
    663
    Are you cutting the driver side cover and front cover, or are you speaking of cutting the gray plastic shroud over the supercharger? If it is the supercharger shroud you're referring to, all that needs to be done is add spacers (washers) to the front pin and rear pins it rides on. Only takes a minute of fitting, and you can still get to the oil fill as if it were almost stock. For the short time I ran it on there for fitment, it did get a black wear line from the insulation under the hood. Then, up on the wall it went, good to go, with no cutting or fitment issues for the next guy someday...why trap more heat?
    ChurchSTSV's Avatar
    Oct 2012
    Chandler,AZ
    33
    369
    The driver side piece. While the main engine cover is pretty, it holds waaaaaaaaay too much heat.
    Rboughne1's Avatar
    Jul 2014
    Jersey
    663
    Yup! Cut right down the driver side covers lower crease, and bevel the cut with a light grind afterwards. It'll saw through the lines running over the air box if you don't. I also noticed that soon after installation the rubber gasket on the top of the airbox at the curve tended to rise. Set it back in place to the curve exactly and you'll have more than enough room.
    Jailtime is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V, 95 Sierra Z71
    Jun 2009
    Velva, ND
    30
    349
    You don't have to modify any of the plastic engine covers to fit over the Spectre intake. Just the metal heat shield, I cut by trial and error. Couldn't have been more than 3/4" at the most. Once the heat shield was trimmed, fit the rubber molding back on, plastic beauty cover on, and enjoy!
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Rboughne1's Avatar
    Jul 2014
    Jersey
    663
    Quote Originally Posted by Jailtime View Post
    Ahhh, more than one way to skin a cat! I was hesitant to cut the box down because I wanted it to seal tight to both the cover and the hood (when closed), as the driver's side cover doesn't cover the whole box. You're right, he same seal could be achieved cutting the box, but I didn't have the patience. Once I determined that I could make my cuts in the plastic appear stock, the decision was made for me! Looks factory if you cut down the lower edge of the cover's longitudinal seam, and notch the cover in a "u" shape from the bottom to the top of the seam and back down again over the back edge of the airbox, as it tracks towards the inner fender, so that it rides tight on the rubber gasket.
    Out of curiosity, how did you get the front cover to fit flat over the nose of the stage 2 intake without cutting?
  12. Remove Advertisements
