my update and my search for an aftermarket Transmission oil cooler !
Results 1 to 3 of 3
Cadillac STS-V Series Forum Discussion, my update and my search for an aftermarket Transmission oil cooler ! in Cadillac V-Series Forums; Hello my Fellow Classy STS-V owners i don't know if what i'm doing is against the forum rules or not ...
    sts454049's Avatar
    sts454049 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Black Raven STS-V
    May 2014
    Kingdom Of Bahrain
    27
    246
    i don't know if what i'm doing is against the forum rules or not since this is my 3rd thread with a different issue each time.
    so my final update for my V is :
    the car was tuned on a dyno jet and my setup so far is :
    - spectre stage 1 and 2 intake
    - borla mufflers with a custom X-pipe
    - Mr.Gasket 160 Degrees thermostat
    my car started with 303Rwhp which was disappointing and the second run it reached 356 and finally 386 on a very hot day ( temperature was 107F ) and my tuner suggested that if i removed the catalytic converters i would gain more especially on better days.
    so on performance wise i'm doing fine i guess ..
    issue wise :
    I've managed to fix the overheating issue, the thermostat and the fan speed tune did good and i replaced my radiator cap, but two new things happened !
    my transmission oil cooler was kinda broken and when the shop tried to fix it it started leaking and i had to drive it to work and take it to the garage when i left work and waiting for it to be ready as we speak, but since i love upgrading any faulty part in my cars, what are the recommendations for an aftermarket replacement because i'm worried about fitment and i'm on a budget currently .
    second issue which is really strange .. after i discovered the leak and when i was leaving work and going to the garage, i started the car and my traction control light is on ! i tried switching it off but nothing happened .. any suggestions or thoughts
    Ninja-v is offline Cadillac Owners Fanatic
    Automobile(s): 2007 sts-v, 2011 Escalade EXT
    May 2013
    28
    375
    Re: my update and my search for an aftermarket Transmission oil cooler !
    Wheel bearing
    sts454049's Avatar
    May 2014
    Kingdom Of Bahrain
    27
    246
    The traction light turned off but I still have the leak issue so I really need some help regarding the oil cooler
