Spectre intake stg 1 & 2 installed .. Radiator cap issue !
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By 1madstsv
Cadillac STS-V Series Forum Discussion, Spectre intake stg 1 & 2 installed .. Radiator cap issue ! in Cadillac V-Series Forums; Hello guys So I installed the spectre intake stage 1 and 2 on my caddie, and it was a bit ...
    sts454049's Avatar
    sts454049 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Black Raven STS-V
    May 2014
    Kingdom Of Bahrain
    27
    249
    Hello guys
    So I installed the spectre intake stage 1 and 2 on my caddie, and it was a bit hard to install but I did it after all, but I had a problem when I was testing the car as when I floored the gas pedal and suddenly the temperature gauge went up and then it started falling down again .. Is it normal since my car is still untuned ?
    One more issue is that when the fluid very warm and the second fan is not working due to the ac off, the radiator fluid will start vaporizing from the cap and it will let go all of the fluid out from the bottom of the car ..
    My father in law suggested it could be the radiator cap that causing the issue ,, so is it possible !
    Dave G is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Apr 2009
    42
    309
    Re: Spectre intake stg 1 & 2 installed .. Radiator cap issue !
    I'm not sure I fully understand but it sounds like you have a few problems.
    The intake by itself won't make fluid shoot out of any orifice, nor will a tune. You could be low on coolant which would make you gauge fluctuate - it'll read water then air then water...
    Is the AC off because of the message on the dash - "engine hot - AC off" or did you turn the AC off?
    It's probably coming out of the cap because it's too hot. If you're lower on coolant the car will run hot.
    sts454049's Avatar
    May 2014
    Kingdom Of Bahrain
    27
    249
    Hey Dave
    Oh no they're too different issues lol and I suck in explaining what I mean
    The issue which is always happening is the radiator issue which as u mentioned that it could be caused by the cap
    My second issue is that when I installed the intake and I wanted to try it .. When I floored the gas pedal the gauge temp went up with no error messages or something at all
    Apr 2009
    42
    309
    I'm gonna guess your coolant level is low and will fix both problems.
    sts454049's Avatar
    May 2014
    Kingdom Of Bahrain
    27
    249
    Let's hope so
    And I'll replace the cap as well just to make sure
    TimmyC is online now Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Just fill the coolant first. One thing at a time.
    Apr 2009
    42
    309
    The radiator cap is designed to let off pressure at a certain pressure. As water heats up it produces more pressure as steam. If your temp gauge is indicating hot - it is. The radiator cap is doing it's job.
    sts454049's Avatar
    May 2014
    Kingdom Of Bahrain
    27
    249
    so i did several things
    i replaced the thermostat with a new Mr. Gasket ( 160 Degrees ) and a new radiator cap, and i dyno tuned the car
    i gained 386RWHP on a very hot day and a very warm engine, my tuner just adjusted the fuel and air with no timing adjustment
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    Dam I want that intake gained. 386hp. Man I would be close to 850hp. And nothing like taking a car with a over heating issue to the dyno. Sitting still and running to 6,800k and 140mph. With no fresh air should fix that right up.
    Guy.Seminerio likes this.
    Apr 2009
    42
    309
    It was the 160* thermostat that gave the 386HP gains.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    I have that it must be the radiator cap. Bet mine is also bad.
    sts454049's Avatar
    May 2014
    Kingdom Of Bahrain
    27
    249
    well i kinda went all the way on this issue to fix it just to make sure everything goes well ..
    i replaced the thermostat and the cap and tuned the fans to work cooler but still my gauge goes up when i floor it so my last hope would be cleaning the radiator itself
  15. Remove Advertisements
