pulley options , exhaust size and the usual questions - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Like Tree3Likes
Cadillac STS-V Series Forum Discussion, pulley options , exhaust size and the usual questions in Cadillac V-Series Forums; I have mine wedged down with an electrical tape wad. About the size of a dime right in the center. ...
  1. #16
    Ninja-v is offline Cadillac Owners Fanatic
    Automobile(s): 2007 sts-v, 2011 Escalade EXT
    May 2013
    28
    378
    Re: pulley options , exhaust size and the usual questions
    I have mine wedged down with an electrical tape wad. About the size of a dime right in the center. Sunroof seems to sit a little more flush now actually. Front driver side corner used to stick up about 1-2 mm. Even at 80 it's still quiet
  2. #17
    sts454049's Avatar
    sts454049 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Black Raven STS-V
    May 2014
    Kingdom Of Bahrain
    27
    254
    So
    I installed my borla mufflers and the x pipe and ill be fitting my spectre intake tomorrow
    I have a problem though
    My upper fan won't work until I start the ac and if I don't the reservoir will heat up and the car will " puke all the water "
    Fan relay maybe ?
  3. #18
    baller95's Avatar
    baller95 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 Cadillac STS-V Black On Black
    Jun 2010
    Toronto, Canada
    26
    1,367
    Just out of curiosity what are the stock pulley sizes on these cars and what's the lowest you can go (safely)?
  5. #19
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    2.8" is stock and 2.6-2.5 depending on your view of "Safely". Most have had good results with a 2.5 without having to change injectors.
    baller95 likes this.
  6. #20
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    2.4" is okay on stock injectors but just barely.
    If you want more boost than that I recommend my lower pulley ring. 27% more blower speed than stock. Good times.
    baller95 and 2007blackbty like this.
  7. #21
    baller95's Avatar
    Jun 2010
    Toronto, Canada
    26
    1,367
    Quote Originally Posted by PGA2B View Post
    Quote Originally Posted by TimmyC View Post
    I see, how many more pounds of boost will I get with a 2.4" or 2.5" pulley? Timmy, how much for your pulley?
  8. Remove Advertisements
