Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Neutral safety switch
    Psycho-albanian is offline Cadillac Owners Fanatic
    Automobile(s): STS_V
    May 2010
    277
    How hard is it to replace by yourself? My car keeps telling me to shift to park when the shifter is in park.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,549
    Re: Neutral safety switch
    You can adjust the linkage.
    I posted a thread about it that I found on some Gm tech website in the normal STS section.
    May 2010
    277
    How hard is it to adjust it?
  5. #4
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Good question. I've had a few instances of, 'shift to park' while I was in park also. Thinking of tackling that job soon.
  6. #5
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    Chicago
    44
    1,328
    To adjust, you will have to get under the car, and on the linkage from the shift lever that extends into the tunnel, there is an adjustment nut on a adjustment sleeve. Loosen that nut and it should self adjust. If not do the following.
    - Hold the selector lever on the transmission against the rear stop in the PARK position to eliminate any play in the forward section of the linkage.
    - Grasp the linkage at the control lever (the shifter handles' linkage that goes under the car).
    - Push the linkage forward and make a note of the amount of travel the rod makes going into the adjustment sleeve.
    - Pull the linkage rearward and make a note of the amount of travel the rod makes coming out of the adjustment sleeve.
    - Place the rod into the adjustment sleeve half the distance of the complete amount of travel.
  7. #6
    May 2010
    277
    Someone said that my shifter assembly might be bad and that needs to be changed.
  8. #7
    CMNTMXR57's Avatar
    Feb 2009
    Chicago
    44
    1,328
    Who is saying this, and what is their basis for saying it. I would think that if your entire shifter assembly was bad (probably contact related), you'd have other issues too.
  9. #8
    May 2010
    277
    Read it on ask.com someone had the same problem and Gm technician told him it was his shifter assembly.
  10. #9
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,549
    The dealers like to do the whole shifter assembly rather than just do a proper adjustment. They can charge more as they are replacing parts and it takes longer to complete so more labor involved. I've seen it talked about many times in various threads in the normal STS side of the forum.
  11. #10
    May 2010
    277
    If it just takes a linkage adjustment that's good. I hate sitting in my car shaking the shifter back and forth waiting for the light to go off.
  12. #11
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,549
  13. #12
    May 2010
    277
    Would a local shop be able to adjust the link?
    Don't want to take it to the dealer so they can rip me off.
  14. #13
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Jack it up and look yourself. It is not hard. There is a slot on the arm that comes off the shifter and a bolt that goes to the transmission arm. It's easy.
  15. #14
    CMNTMXR57's Avatar
    Feb 2009
    Chicago
    44
    1,328
    I posted the steps above in post #5. It's really easy. Once you loosen the adjustment nut, it should do it itself, but if not, the steps are above.
  16. #15
    May 2010
    277
    Adjusted the link still not working. It might be the neutral safety switch after all.
  • You may not post replies
