Increasing Gauge cluster brightness
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree2Likes
Cadillac STS-V Series Forum Discussion, Increasing Gauge cluster brightness in Cadillac V-Series Forums; Has anyone done this? I can do it with my T2, but it won't let me keep it and set ...
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,312
    Has anyone done this? I can do it with my T2, but it won't let me keep it and set it at those levels. It is purely for a testing purpose.
    Reason I ask, is in the beater (the Suburban), I was getting tired of the dull low powered light, so I ordered a bunch from SuperBrightLEDs.com and it made a night and day difference. So much in fact, that once I got into the Caddy this week, I was rather let down by the level of brightness by comparison.
    Has anyone done this on our clusters? Ours being LED from the factory, are they hard soldered in-to-the board LED's? Or are they twist/pop out style like the 194's or 74's that I replaced on the 'Burb? I'd almost like it as bright, similar to when you don't have any lights turned on at night (I.E. the auto-dimming feature when you turn on the lights).
    Just so you can see, here is before and after pics of 'Burb;
    Before (regular 194 bulbs);
    After (warm white, 360*, 15 SMLED wedge base bulbs);
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    Re: Increasing Gauge cluster brightness
    I'd bet that they are soldered SMD LEDs ... I did a filament to LED swap in my monte carlo (as several had burned out) and had to desolder the little lamps and solder in some new LEDs and resistors.
    In the STS application I'd assume the T2 is allowing you to force full 'daytime' brightness regardless of it being day or night out as reported by the twilight sentinel on the dash and that is why it doesn't allow you to keep it set.
    The Monte used lamps like this in its cluster (with a couple of LEDs as well for the MIL and I think the airbags as well):
    http://www.radioshack.com/product/in...ductId=2104023
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,312
    The T2 just allows for 10% increment changes to test the backlighting. At night, it usually drops it to 90%. So with the T2 hooked up, I can manually adjust up to 100%, but it won't let me set and save or override the auto-dim.
    I figure that they're hard soldered unfortunately.
  5. #4
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,595
    We have a gage cluster?? That's odd In my car I just look at the windshield lol.
    Ludacrisvp and 06 STS Rob like this.
  6. #5
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,312
    HUD lover...
  7. #6
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    Quote Originally Posted by CMNTMXR57 View Post
    HUD lover...
    So add one to yours... 1BadCadSTS is adding an OEM HUD to his 05 STS4.
  8. #7
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    27
    2,337
    Has he started a thread for his mod yet?
  9. #8
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    Lol yea probably about a year ago. He mentioned that he was planning to do it finally on a weekend recently on Facebook but it would seem that it may not have been completed.
  10. #9
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    Negative. I need someone to help as the dash is a large piece and do not want to break it. If anyone's around Pittsburgh pa and wants to help in the undertaking it will be a learning experience and all meals are included hahahahhaha.
  11. #10
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,312
    Quote Originally Posted by Ludacrisvp View Post
    I seem to recall someone discussing this years ago (back when I first joined), and it wasn't an easy process. As much as I love HUD (one of the things about all my Pontiac's that I miss), cost vs. benefit ratio isn't there for me to retrofit it. On top of which, It is not as if you're getting a full gage package in the HUD display. Just MPH, turn signals, radio frequency, and maybe in this particular application, a boost gauge etc...
    I actually like gauges, in particular the tachometer. "One eye tach, one eye track" is what I was always taught in drag racing 101. Granted that's more important for a manual transmission car. The point is, I like bright, legible, functioning gauges. Not a digital readout hovering in my lower eyesight. It's nice, but not the same.
  12. #11
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    HUD displays Speedo and Tach in sport mode and a check gauges message if you need to be alerted to the other gauges. It also shows radio channel, navigation direction with status bar, lamp indicators, and current gear in sport mode....
    I have all the parts needed for the retro fit, I have $250 bucks in it. Id say its well worth the cost if you do it right.
  13. #12
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,595
    Yep the HUD in this car is much better than the Pontiac's.
  14. #13
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Not a big deal but it also shows climate temps. :-)
  15. #14
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    My 08 w/ ACC:
    Guy's 09 V:
    Guy's 09 V (showing the speed advisory that was available in 09+):
  16. #15
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Yeah it's nice being able to launch in manual mode and shift right before redline without having to look down at the rpms. It's right there where you should be looking when doing those speeds.
  17. Remove Advertisements
