"service stability sys, service brake assist" - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
Like Tree3Likes
Cadillac STS-V Series Forum Discussion, "service stability sys, service brake assist" in Cadillac V-Series Forums; I laugh at that, but I saw sh*t like that all too much... And believe it or not, upon telling ...
  1. #16
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,317
    Re: "service stability sys, service brake assist"
    And believe it or not, upon telling the owners of this, some would actually ask me to put it back together and "how many more miles can I get before I absolutely have to fix this?"
    At which point you just stand there like a deer in headlights due to their utter stupidity and/or cheapness. These are the people you share the road with!
    Ludacrisvp and Guy.Seminerio like this.
  2. #17
    zek4964 is offline Cadillac Owners Fanatic
    Automobile(s): 08 cts 68k, 07 STS-V 15K, 97 Sts 160k
    Jun 2010
    Rochelle IL
    302
    On my CTS I got that message to service stabilitrac and it was the magnetic strip in the wheel bearing that was bad. At first the tech did not think it was the wheel bearing and called me to be sure I wanted it replaced I said yes and once the new bearing was in no more problem. But like I said that was on an 08 cts.
  3. #18
    264WOODY is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac STS-V
    Aug 2013
    DAYTON, OHIO
    85
    Just to keep everyone up to date on my V's situation, the dealer has determined that the steering wheel position sensor is intermittently losing signal. Also one of the rear hub bearings are defective and is throwing codes. They want the hub bearing replaced so they can clear out the codes, and then further diagnose the steering wheel position sensor. Since the rear hub bearings are practically new, I will replace it myself and then return it to the dealer, for the steering wheel position sensor issue. Thus far i'm into the dealer for 2hrs of diagnosis. I'll keep you posted on the final results.
  5. #19
    Aug 2013
    DAYTON, OHIO
    85
    Finally replaced the rear hub bearing, and it was bad. evidently two of the bolts worked loose and caused failure of the bearing (broken wire) and that fixed the codes, as for taking it back to the dealer so they can tell about the steering wheel sensor that is "intermittent" not yet, not really looking foreword to more trouble shooting costs on something that they say they haven't been able to get it to "act up yet".
  6. #20
    rwwrrr is offline Cadillac Owners Member
    Automobile(s): STS-V 2008
    Apr 2010
    49
    36
    I have these lights on also but my car is shaking and vibrating and seems like the engine is running super rich. Traction control system light is on and the service engine is flashing and my car makes the noise like a seatbelt is not fastened.
  7. #21
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,531
    flashing SES light is causing damage to the car ... severe misfire detected...
    Get the car to a competent shop (dealer) that deals with high performance cars / caddys on a daily basis.
  8. #22
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,695
    Quote Originally Posted by rwwrrr View Post
    Hello rwwrrr,
    I can understand why you would be concerned. I apologize that you are experiencing these symptoms with your STS-V. If you are planning on working with your dealership and would like our assistance, please PM us your full contact information, VIN, current mileage, and involved dealership.
    Kind regards,
    Jonathan A. (Assisting)
    Cadillac Customer Care
  9. #23
    YoungBlood_STSV is offline Cadillac Owners Fanatic
    Sep 2010
    277
    Quote Originally Posted by Ludacrisvp View Post
    What is your opinion on the most likely cause to this...?
  10. #24
    Apr 2010
    49
    36
    Damn, that is not what I wanted to hear. I wonder if the engine will blow? Throw a rod? I thought it was electrical or maybe rear motor mounts and hoped I wasn't causing further damage.
    I will try to take it in tomorrow to my Fresno Cadillac dealer Michael Cadillac they replaced the accidental damage that occurred during a previous service, however have not been the same socially since I wrote on this site about how the work was becoming sub-par. They really have done a wonderful job since then when replacing the drive shaft, bearing pack, top radiator hose, etc. I have 110k miles on this 08 and these are not pretty miles.
    Any idea what severe misfire could be?
    Coil?
    I wonder how much that will cost?
  11. #25
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    What codes are present? Can't make any guesses without some more info. What happened right before the car started running rough?
  12. #26
    Apr 2010
    49
    36
    No idea on the codes, I am taking it in tomorrow to the Cadillac dealership. They have done all the work to it since 7,500mi, has 110k now.
  13. #27
    Mar 2010
    Detroit, USA
    12,695
    Hello rwwrrr,
    I see you are bringing your vehicle into your nearby Cadillac dealership. If additional questions or concerns arise, please feel free to send us a private message. We are always more than happy to assist anyway that we can. Please keep us updated after your dealer service visit.
    Laura M.
  14. #28
    Apr 2010
    49
    36
    So far its a spark plug and coil but the engine still has a few more codes showing up...
  15. #29
    Sep 2010
    277
    Hey guys. I'm going to be honest...I'm lazy today.
    What spark plugs are the recommended ones? Tr7xi or something?
  16. #30
    06WhiteDiamond is offline Cadillac Owners Fanatic
    Jan 2012
    28
    320
    Quote Originally Posted by YoungBlood_STSV View Post
    I just put in Tr7xi plugs, no issues.
    YoungBlood_STSV likes this.
  17. Remove Advertisements
