Supercharger
Results 1 to 9 of 9
Cadillac STS-V Series Forum Discussion, Supercharger in Cadillac V-Series Forums; Hello out there I have a question. Long story short I was installing the Timmy C intake yesterday broke a ...
    iLuvEasy is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V Raven
    Oct 2013
    Houston
    34
    Supercharger
    Hello out there I have a question. Long story short I was installing the Timmy C intake yesterday broke a couple of bypass hose on the back replace them already. But there's three ports on the back of my SC I know two are Supercharger Bypass Valve Actuator Hose Vacuum Source to Actuator and the other is maybe the same. The one in the middle just has a rubber plug over it. Is it useless or does it need to be connected to something?
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,537
    Re: Supercharger
    This should be the answer you need.
    Quote Originally Posted by CMNTMXR57 View Post
    That middle one (#819) that is purposely meant to be open, as it is an outlet sensor of some sort. You have an inlet, and barometric pressure sensor also. Here is an exploded parts view I got from the parts department when I too inquired. You can also see the tubes that attach to #818 and #820 (parts #816 & #817). Personally, I bet he wrote them down wrong because it would make sense that the inlet and outlet sensors are hooked up via those tubes and the barometric pressure one would be "open-air".
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Re: Supercharger
    This picture shows the vacuum lines in question. Not sure where that last one is connected to, however.
    http://caddyinfo.com/wordpress/wp-co...06PT-PP012.jpg
    Oct 2013
    Houston
    34
    Quote Originally Posted by Fierofiend
    This picture shows the vacuum lines in question. Not sure where that last one is connected to, however. http://caddyinfo.com/wordpress/wp-co...06PT-PP012.jpg
    That what a though at first but I had to recheck to make sure that it was three. I think this picture from the xlr-v
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Re: Supercharger
    Plugged one stays plugged.
    Oct 2013
    Houston
    34
    Ok. Tim I can feel the change on that intake
    Feb 2009
    37
    1,897
    Re: Supercharger
    You're going to need to get that tuned for the intake.
    Feb 2012
    Charlotte, NC
    338
    Re: Supercharger
    Tim, do you usually recommend full maf/ve tune just swapping intake, or is just the MAF table fine to start?
    Feb 2009
    37
    1,897
    Re: Supercharger
    Maf table is fine to start. The ve is almost impossible to tune with variable cams anyway.
  12. Remove Advertisements
