06 sts-v head gasket probs?
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By 1madstsv
  • 1 Post By Guy.Seminerio
Cadillac STS-V Series Forum Discussion, 06 sts-v head gasket probs? in Cadillac V-Series Forums; Hi all, So I have a 06 sts-v 40k miles. I bought it used a year ago, I love it... ...
    thedude560 is offline Cadillac Owners Member
    Apr 2013
    42
    7
    Hi all,
    So I have a 06 sts-v 40k miles. I bought it used a year ago, I love it... But, I started getting the engine hot ac off message. I replaced the thermostat, it went away for a while then came back on.. ugh so, seeing as how I have the extended warranty I dropped it off at the dealer. they pressure tested the block and determined it to be bad head gaskets (exhaust in the coolant). damn... so anyways... after fighting with my aftermarket warranty provider for around 3 weeks as to whether or not it would be covered, they finally agreed to cover most of the repair costs.
    Anyone else had issues with the head gaskets? The dealer is doing timeserts in the block with the new head gaskets, how do you guys feel about this as a viable repair for the block thread issues?
    I'm kind of concerned with this being a supercharged motor that the timeserts will pull out, I'm supposed to get the car back on Monday after 5 weeks. What do you guys think... Should I sale/trade it? Or will the timeserts be a repair that lasts? Anyone with a supercharged car out there have this done?
    Thanks, Jim
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    Re: 06 sts-v head gasket probs?
    I haven't heard of it being needed on a S/C version, but the older FWD version of these engines used to have quite a few problems where timeserts were used to repair them. I've never heard of a timesert repair having the same problem again, I hear they're quite durable.
    The Northstar used to be a pretty fragile engine, I thought that was fixed in the newer RWD applications. I've owned three other of the older variety of Northstar engines, four if you count my Olds Aurora (baby 4.0L Northstar design). Two of them had engine case halves that required the engines to be pulled and resealed due to oil leaks. None of the older cars seemed to ever leak again after the fix in the field.
    The reason I brought up the oil leak is I wonder why GM doesn't use some type of steel insert in the aluminum blocks to prevent this type of failure mode. It seems to me GM always took a gamble that they would never need to fix it in the field under warranty, or gamble that it wouldn't have a failure until after the warranty period was over.
    I bought my 07 a little over a year ago, 79K miles then, 95K miles now. Hopefully I won't regret buying mine later, and hopefully I won't run into any type of warranty issues if I ever have to claim a major repair like this.
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    This is the first Stsv I have ever heard of blowing a head gasket. Very odd the 4.4l was designed to fix this problem. I ran 18/19 psi of boost in my 06 from 65k/95k miles with out any engine issues at all. And drove at 100+ every time out with it. I live in Mexico so it's ok.
    Guy.Seminerio likes this.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    I'm thinking all of us on the v forums have lived in Mexico at one point or another.
    Dave G likes this.
    youknooow is offline Cadillac Owners Enthusiast
    Automobile(s): STS-V 1 OF 3 BLK ICE & TANGO RED
    Dec 2010
    628
    I've gotten the hot AC message once maybe twice but I "resolved" it by un plugging the battery. I haven't noticed any compromised performance so I concluded it was a glitch thoughts?
    Apr 2013
    42
    7
    Quote Originally Posted by youknooow View Post
    I didn't notice any loss of performance either, nor was the engine over heating. I'd clear the codes and it
    would come back in two days or so. I tried replacing the thermostat as others have had success with. But,no luck. From what I gather, the coolant heated up faster then ecu expected because of the exhaust
    gases in the coolant. I guess it is, what it is...I'm just concerned that the timessert are going to ruin the
    block.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    You'll be fine with the inserts. These things are not known for head gaskets so I'm very surprised that you had a problem.
    Apr 2013
    42
    7
    Timmyc,
    I've read through some your posts, it looks like you know your way around a caddy. Thanks for replying!
    I suppose maybe I'm worried about nothing, I hear a lot of the import guys have block issues that they cure with inserts. I spoke to a friend of a friend, who's a caddy tech today. He says, serts are the norm on a aluminum block when the heads are removed. Although he's never seen a sts-v have a bad gaskets either. He wouldn't do it without them. He also told me to keep up on the antifreeze flushes. And it will be fine. Dealer says I should have it back on Monday. Lol, weatherman is calling for 12 plus inches of snow on Monday. That's my luck.... So maybe later in the week I'll get it back.
    Anyways, good forum you guys got here. Thanks to all who replied.
    Jim.
  11. Remove Advertisements
