Passenger Door and trunk will not work
Results 1 to 7 of 7
Cadillac STS-V Series Forum Discussion, Passenger Door and trunk will not work in Cadillac V-Series Forums; Has anyone had experience with passenger door not working from the outside. Light wont come on like normal. I must ...
    WFOWFO64 is offline Cadillac Owners Member
    Automobile(s): 64 Fleetwood, 06 STS,11 Escalade Super Charged,06 STS V
    Feb 2014
    21
    Has anyone had experience with passenger door not working from the outside. Light wont come on like normal. I must open from inside only. Trunk will not pick up fob but will work if you push fob.
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,313
    Re: Passenger Door and trunk will not work
    Does the door open when you pull the handle outside though? Or is that inoperative too?
    If it's a matter of the passenger side doesn't unlock and the trunk doesn't respond to the FOB, that is a communications issue with the receiving module(s) located at various points through the car, in this case it sounds like the passenger side/rear antenna's may not be picking up the signal. At which point you then have to determine whether or not it's a FOB issue (low battery, resynching issue, etc), or if it's the module.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Sounds like the passenger door handle is bad. I've seen that before. The tiny switches in it aren't working right. A new door handle is around $80-$90 from the dealer. You just need the part that goes inside the door, not the actual handle.
    The inside door handle is connected to the latch with a cable. The outside one is strictly electrical. That's why the inside works and the outside doesn't.
    I've seen the trunk button go bad too. I replaced the button part on a car once but that did not fix it. I sold that car and got one with a working button so I don't know how to fix that.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by WFOWFO64 View Post
    Hi WFOWFO64,
    It looks like other forum members have already given you some solid feedback. If you do decide to head to the dealer, I would be happy to set up an appointment if you shoot me a PM with your VIN and contact info. If you are unable to PM me, please email me at socialmedia@gm.com with "Attention: Austin" in the title. Have a great day.
    Austin J.
    Cadillac Customer Care
    Feb 2014
    21
    Thanks guys. Im going for handle, light doesn't come on. I have my wrecked sts still so I may pull trunk button out and check it out.
    Feb 2009
    37
    1,894
    What light are you talking about?
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Red light on front door in place of a pull up nub thing like they have in the back.
  10. Remove Advertisements
