Front sway bar bushings.
Results 1 to 6 of 6
Cadillac STS-V Series Forum Discussion, Front sway bar bushings. in Cadillac V-Series Forums; Okay, so I got my passenger side bushing changed today, but I see no way to possibly get to the ...
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Okay, so I got my passenger side bushing changed today, but I see no way to possibly get to the front bolt on the driver side. Does anyone have any tips or advice?
    "Easy" one installed....
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    Chicago
    44
    1,328
    Re: Front sway bar bushings.
    Back down the bolts on the front sub-frame assembly on that side. Don't take them out completely, just enoug to drop it down on that side to get you clearance.
    Feb 2012
    Charlotte, NC
    338
    I'll give that a try. I had to order the rears, so when they come in I'll give this one another go. I considered lowering the subframe but everything is so tight in the engine bay, I wasn't sure if it was a good idea. I think if I gain another inch or so, it should be good enough.
    Thanks!
    CMNTMXR57's Avatar
    Feb 2009
    Chicago
    44
    1,328
    I know the feeling. As long as you don't pull the bolts out completely and you have something to support that side of the subframe you should be ok. There won't be subframe re-alignment issues when you go to re-torque them up since you didn't pull them out completely.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    +1 and it is a PITA!! I remember when I put in my Poly Bushings!!
    Feb 2012
    Charlotte, NC
    338
    Hopefully it will be worth it in the end. After both sway bars I'm going to look into replacing the rear trailing arm bushings. I'm hoping they're similar size to the cts-v. Ours cross reference with srx, but that's not exactly a good lead for aftermarket.
  9. Remove Advertisements
