Thermostat problem explained
Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By TimmyC
Cadillac STS-V Series Forum Discussion, Thermostat problem explained in Cadillac V-Series Forums; Like many other STS-V owners before me, my thermostat went south on me last week. Just like everyone else, mine ...
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    Like many other STS-V owners before me, my thermostat went south on me last week. Just like everyone else, mine stuck open. Most thermostats don't fail open, they fail closed since that is the default state. There is a stiff spring holding them shut. Being curious I removed it and the problem was immediately apparent.
    There is a gasket that seals the thermostat when it's closed. The gasket rips and the car won't warm up. Eventually you get a p0128 code for a bad thermostat. The response to the code being set is the "Engine Hot-AC Off" message and activation of the electric cooling fans.
    The solution is still the same-new thermostat-but at least we know what is going on now.
    mjs182004 and Guy.Seminerio like this.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,983
    Interesting. Thanks. Still funny that the car acts like it's hot.
    Sent from AutoGuide.com Free App
    deadringer's Avatar
    deadringer is offline Cadillac Owners Fanatic
    Automobile(s): Modified 06 XLR-V
    Jul 2004
    Houston, TX
    164
    Re: Thermostat problem explained
    Is that the stock thermostat that was original to the motor? or a 160deg replacement?
    Feb 2009
    37
    1,895
    60,000 mile original
    SCCAForums is offline Cadillac Owners Member
    Nov 2013
    32
    Yep, mine stuck open as well at 56K miles... I ended up putting in a Lingenfelter 176... with new OEM rubber gasket, and haven't looked back.
    Nice diagnosis!
    Dave
    mike101344 is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V
    Feb 2014
    4
    My '06 STS-V temp gauge started to read low. I replaced the thermostat myself and all is okay now. No visible problem found. I needed to disconnect the lower hose as the thermostat and gasket were stuck in the housing and needed to be pryed out. If you do it yourself, plan for an hour and be sure you know how you are going to re-clamp the lower hose. I wired mine and then snapped the wire when it was in position, but I suggest an aftermarket screw clamp. I lost about a quart of antifreeze and haven't replaced that yet.
  9. Remove Advertisements
