STS-V Continuing to disappoint. Engine power reduced and Ignition shut off lights.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac STS-V Series Forum Discussion, STS-V Continuing to disappoint. Engine power reduced and Ignition shut off lights. in Cadillac V-Series Forums; I was at ared light and my Engine power reduced light came on, after limoing into a parking lot, the ...
    HUGHS STS-V is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade, 2005 STS V6 , 2006 Escalade Ext, 2006 STS-V
    Feb 2012
    Hinckley,Ohio
    27
    28
    I was at ared light and my Engine power reduced light came on, after limoing into a parking lot, the ignition shut off light came on and the car lost power steering etc. I unplugged the battery and its been fine, I ve only driven it like 5 min after it happened today. I still have the lean codes as well as the t/c and abs. Anyone know what is going on?? I'm trading it in next week just want it to be ok. Because I work at the dealership.
    Dave G is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Apr 2009
    42
    317
    Re: STS-V Continuing to disappoint. Engine power reduced and Ignition shut off lights
    I'm not saying this will fix it but...on my wife's TBSS she had the 'reduced engine power' light come on last week. I disconnected the battery and it came back on a day later. Next, I pulled the throttle body off and cleaned it. Reinstalled, disconnected the battery and it hasn't been on since. Without a scan tool, it's kinda hard to know for sure what the issue is but it 'fixed' it for me.
    Feb 2012
    Hinckley,Ohio
    27
    28
    How hard is it to pull the throttle body??
    It did say "starting disabled, throttle problem" after saying "engine power reduced."
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,661
    If you work at a dealership see if one of the techs will hook it up to a Tech II and see what it says.
    Feb 2012
    Hinckley,Ohio
    27
    28
    I will try to find someone with one, I am trying to trade it in to my dealership so I don't really want to have all the problems known. Off hand is there common things that go that would cause this, a friend said running lean, trans, etc. I think I have at least one bad cat and an 02 sensor, So I was leaning toward the running lean..
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    It's all guess work till you get the codes pulled. Go to autozone and have them do it if you don't want to do it at work.
    Feb 2012
    Hinckley,Ohio
    27
    28
    Ok, I understand. I'm just terrified that the car is going to break down on me on the way there in the middle of a main stretch. I'll keep the thread updated and I appreciate all the help/input. With that being said, anyone want a STS-V.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by HUGHS STS-V
    I do haha
    Feb 2012
    Hinckley,Ohio
    27
    28
    Im trying to get 12k to payoff my debt
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    Mine did that, new FB fixed it. Only takes me about 15min to replace the tb, but I've done it. A lot
    Feb 2009
    37
    1,894
    Quote Originally Posted by HUGHS STS-V View Post
    How many miles?
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by boomys10
    What's a fb?!
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Typo. Tb. I'm guessing.
    Ah you're breaking his balls. Got it.
  16. #14
    WFOWFO64 is offline Cadillac Owners Member
    Automobile(s): 64 Fleetwood, 06 STS,11 Escalade Super Charged,06 STS V
    Feb 2014
    21
    Hugh, I got your car. we are starting with fuel filter then checking fuel pressure. Filter is almost completely plugged so we need to ck pump. It is missing so bad that I'm thinking fuel pump. I don't have time to ck now. Out of town for a week but I will update you. The other light on the dash have went out and came back on. Air bag light is off now. The wheel bearings are so bad this could be the problem. If it is the control unit I'm ok I still have my wrecked STS. You really had kept this thing looking good. This is my second STS V I also had a 2008. My wrecked STS is a platinum and window stickered for more than my V. 2006 with 163,000 and the air bag light acted up on it once in a while. Other than that best car ever. Ill keep you updated.
  17. #15
    Feb 2012
    Hinckley,Ohio
    27
    28
    I'm glad it went to a good home!, I will ship out the cover and intake next week.
  18. Remove Advertisements
