STS-V Continuing to disappoint. Engine power reduced and Ignition shut off lights. - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Cadillac STS-V Series Forum Discussion, STS-V Continuing to disappoint. Engine power reduced and Ignition shut off lights. in Cadillac V-Series Forums; Hugh, looks like cat plugged which is causing all kinds of issues 1. heat has melted valve cover gasket 2. ...
  1. #16
    WFOWFO64 is offline Cadillac Owners Member
    Automobile(s): 64 Fleetwood, 06 STS,11 Escalade Super Charged,06 STS V
    Feb 2014
    21
    Re: STS-V Continuing to disappoint. Engine power reduced and Ignition shut off lights
    Hugh, looks like cat plugged which is causing all kinds of issues 1. heat has melted valve cover gasket 2. Valve seals 3. Possible intake leak or much worse. Not sure how much stuff I'm fixing at once. Cat first see how it runs. I've got all the hubs replaced and brakes on front done. No more lights and it is really Quite now. I'll keep you posted.
  2. #17
    Feb 2014
    21
    Hugh, cat fixed it. Runs like it supposed to.
    Now were onto valve cover gasket.
  3. #18
    Feb 2014
    21
    Tightened valve cover seems to fixed it. Just a couple little things now like door handle. Hugh when it was hit did they work on the passenger door?
  5. #19
    HUGHS STS-V is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade, 2005 STS V6 , 2006 Escalade Ext, 2006 STS-V
    Feb 2012
    Hinckley,Ohio
    27
    28
    That's great to hear! There wasn't any work done to the car post collision. It was just buffed and it was primarily the rear driver side door. Continue to keep me posted!
  6. Remove Advertisements
