2008 STS-V Problems post-engine swap - Page 2
Results 16 to 30 of 34
Like Tree3Likes
Cadillac STS-V Series Forum Discussion, 2008 STS-V Problems post-engine swap in Cadillac V-Series Forums; The additional lights did go out upon removing the scanner then starting. Ran the crank relearn last night. Still have ...
  1. #16
    Assault Pilot is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V
    Jul 2011
    Frisco,TX- subarb of Dallas,TX
    39
    12
    Ran the crank relearn last night. Still have random misfire code. Idles better, throttle seems to be better responding.
    But I don't have the time or money to continue if I have to open the engine again, so I'll wait till summer
  2. #17
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,528
    Assuming good plugs and coils?
    Sent from AutoGuide.com App
  3. #18
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,317
    Re: 2008 STS-V Problems post-engine swap
    When you get a P0300, you should also get a P030x, the "X" being the cylinder(s) being affected by the misfire. If not, a good scan tool usually offers either both a current misfire section/chart/table and/or a history misfire section/chart/table, and you should be able to isolate it.
    As mentioned this is an interference engine, and if timing was off like you say... Potential bent valve from contact. But if that were the case, I would think you'd probably have quite a few bent ones.
    Some thoughts before digging into the engine;
    1) Coil Modules.
    2) Connectors for each coil module.
    3) Main ignition feed harness (that connects the coil modules). Ensure that all connections for #2 and #3 all pins are contacting. The harnesses don't offer a lot of slack, in them so it doesn't take much to pull a pin out enough to cause a poor connection
    4) Cracked plug.
    5) Are all injectors firing? Same thing as the ignition, check all electronic connectors, check that injectors are properly sealed within the fuel rail and engine, and the rubber "O" rings at each end are sealing properly. If so, then do an injector balance test (not sure if your scanner can do this). But essentially it involves connecting a pressure gauge to the end of the fuel rail, then commanding each injector to fire. With each firing, you should see the pressure drop consistently (not sure how much ours would drop it, but from doing this on other GM vehicles with a T2, it's usually 5 - 10 psi drop). Then when you find one that isn't in synch with the others, or not dropping at all, you've found a bad injector.
    6) No MAF, MAP, TPS, or other sensor related codes?
    7) Since your timing was off, and you were running the engine, it's quite possible that on a cold, open loop operation, running engine, extra fuel was dumped into the exhaust (I.E. Cats), and more or less, they're clogged and/or both pre-cat and post-cat HO2S's on the respective banks are fouled. This is a long shot, but I've seen it happen before. It is also a key when the vehicle can't get over say 40mph and can't rev past 3,500rpm.
    Just trying to throw out ideas.
    BTW, thanks for your service.
  5. #19
    Jul 2011
    39
    12
    Thank you all for your feedback and thank you for the support!
    I am checking everything everyone is noting if I am able.
    All plugs are good
    I will check coils today
    CMNTMXR57
    Coils are on my list today to check
    I'll recheck connectors
    recheck main harness
    plugs were good when I put the engine in, could the run with off timing affected a plug?
    *on a side note the original timing was not off by much, for what its worth good or bad
    Need to research injector process you indicate
    No other related codes
    I'm leaning away from #7 due to: it easily revs up high, and I had it at 55mph doing a manual crankshaft variation relearn
    I redid the relearn when I got my SCT X3 back and operational.
    On that note, I did a preliminary data-log this morning:
    Cylinders #1, #3 and #5 are the misfire culprits.
    No misfires on any other cylinders
    Ok, I am reviewing playback now, this is interesting.
    The rate of misfire has a pattern
    At 15 seconds
    Cylinder #1 misfire count is 32
    Cylinder #3 misfire count is 15
    Cylinder #5 misfire count is 3
    at 30 seconds
    Cylinder #1 misfire count is 78
    Cylinder #3 misfire count is 57
    Cylinder #5 misfire count is 9
    at 45 seconds
    Cylinder #1 misfire count is 109
    Cylinder #3 misfire count is 78
    Cylinder #5 misfire count is 21
    I'm going to research datalogging and see how to monitor injector pulses and plug/coil firing if possible. And try to digest this pattern above.
    What side is cylinder 1 on? Passengers side??
    P.S. My old helicopter unit in the 101st is doing the flyover for the Superbowl, my buddies are all bragging to me right now..be sure to watch for them!
  6. #20
    Jul 2011
    39
    12
    It appears as if cyl #1 misfire is constant. Upon increase in RPMs, #3 and #5 misfires disappear or slow significantly.
    I'm going to check spark plug on #1, I will move the coil from #1 to see if misfire follows the coil.
  7. #21
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    Do a compression check on those cylinders. The odd numbers (bank 1) are on the passenger side. Isn't that the bank that had the cam timing problem?
  8. #22
    Jul 2011
    39
    12
    WOW
    Found the problem. Pulled the #1 spark plug out for the compression test, spark plug was damaged and pinched. So I look down the hole. Appears there is a nail or something like that stuck in the exhaust valve. I inspected the engine when it arrived freight, I suspect the smallest of my three offspring may have poked this object into the exhaust port. I've found tools in my exhaust on my Jeep before, wrenches on strange orifices around the jeep as well...
    ....fan-f-ing-tastic. He's going to do pushups until I can afford another engine..or rebuild this brand new engine.
  9. #23
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,528
    ouch...
  10. #24
    parkeraire's Avatar
    parkeraire is offline Cadillac Owners Fanatic
    Automobile(s): 06' sts-v
    Mar 2011
    Lee Co. FL.
    47
    169
    Don't be to hard on the little guy. Sounds like he might be trying to fix dads car for him.
    Guy.Seminerio likes this.
  11. #25
    Feb 2009
    37
    1,895
    The repair is going to be a lot of work but might not be that expensive. You might just need a few valves.
  12. #26
    carter's_sts is online now Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,980
    That's crazy. That's just one of those crazy unexpected things. Kind of like the Broncos playing that badly.
    Sorry for your bad luck. I'm sure your kid meant no harm.
  13. #27
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,528
    Quote Originally Posted by carter's_sts View Post
    i'm sure all the seahawks fans expected the broncos to play that badly... did the broncos even show up or did they send in a group of stunt doubles?
    Hopefully the repair will be as simple as swapping out a few valves.
  14. #28
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    Try living in Washington state and not being a Seahawks fan, bandwagon everywhere..... Hopefully you get the V up again ive been keeping up on your thread In case I ever have to do something similar
  15. #29
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    where did you get the engine from? im in the market for another one. thanks for info! also, if you would want to ship the old one to me, we might be able to work something out. message me!!
  16. #30
    Livyx is offline Cadillac Owners Member
    Jan 2013
    36
    22
    Hey Boomy, you can get them on Pace Performance. http://paceperformance.com/i-6485095...er-engine.html
    But even at $9700 it is still a lot for an engine.
  17. Remove Advertisements
