I'm leaking gas
Results 1 to 14 of 14
Cadillac STS-V Series Forum Discussion, I'm leaking gas in Cadillac V-Series Forums; Every once in awhile when I would drive the car I would get a strong smell of gas.. Now it ...
    pjeter is offline Cadillac Owners Member
    Mar 2012
    51
    I'm leaking gas
    Every once in awhile when I would drive the car I would get a strong smell of gas.. Now it seems to be dumping fuel out the bottom. It starts and it runs and all the fuel lines on top seem to be ok... Any suggestions on what to look for?
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Feb 2007
    Naperville, IL
    393
    Re: I'm leaking gas
    The fuel filter is under the car below the passenger seat. That's what was making the "whistling" noise on mine whenever it got cold. Replaced and all is quiet. Check connections to the filter if the leak is under your car (put down some cardboard to see where the leak is).
    Mar 2012
    51
    It's coming out of the bottom of the engine bay near the fire wall ... It pours out near the headers
  5. #4
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,892
    Re: I'm leaking gas
    There is only one fuel line that comes up there. The main line. Sounds like there is cut in it somewhere. Better get that figured out before you have a fire.
  6. #5
    Mar 2012
    51
    I'm gonna get it up on the hoist in the next couple of days and take a look and maybe get a video
  7. #6
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,312
    Re: I'm leaking gas
    If it is leaking near a header, I hope you're having it towed! Sounds to me like a return line.
    To add humor, my Wife often complains about the same thing with me...
  8. #7
    Feb 2009
    37
    1,892
    Re: I'm leaking gas
    The return comes off the filter/ regulator near the right rear wheel. Only the main line goes forward from there.
  9. #8
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,312
    Re: I'm leaking gas
    There is no return from the fuel rail? I can't say I've actively researched our fuel system on this car.
  10. #9
    Feb 2009
    37
    1,892
    Re: I'm leaking gas
    No return from the rail.
  11. #10
    Mar 2012
    51
    I found the leak seems to be coming from the top of the injector. I couldn't see it at first because the intake was blocking it
  12. #11
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    Did you properly install the metal clip that holds the injector in place on the rail?
  13. #12
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Re: I'm leaking gas
    Check for a pinched or nicked "O" Ring.
  14. #13
    Automobile(s): stsv
    Mar 2013
    491
    Any luck figuring it out?
  15. #14
    Psycho-albanian is offline Cadillac Owners Fanatic
    Automobile(s): STS_V
    May 2010
    277
    Re: I'm leaking gas
    Metal clip was the culprit replaced all of them.
  16. Remove Advertisements
