Utlimate goal - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 57 of 57
Like Tree4Likes
Cadillac STS-V Series Forum Discussion, Utlimate goal in Cadillac V-Series Forums; That's what I've said before. It's the thermal exchange in the laminer cores of the intercooler that sucks. Just adding ...
  1. #46
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,313
    Re: Utlimate goal
    Just adding a bigger cooler and pump, just means you get to push more water around. Hopefully because it is a bigger capacity and quicker pumping getting cooler liquid to the cores, and getting the hot stuff back, but...
  2. #47
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    Re: Utlimate goal
    The meth lowers the iat2 buy 10-15 for the 08 car stock boost level our less lol. And 30-40 for the 06 that had 20psi and 200*iat2 on a 75* night. So it helps with the higher boost cars. But most are only 1-2 psi oner stock not 6-7. And I had a 4 gal cell in the truck and needed to fill it every 2 weeks only driving 300-400 miles in that time. The 08 only holds 1.5g and I run it out in a day so I turned it off. We get in to boost so fast it sprays all the time. The 06 was a progressive kit so that helped a little but that's more $$$ up frount. Just some things to think abought.
  3. #48
    Loner is offline Cadillac Owners Member
    Automobile(s): 2005 DTS, 1997 Deville, 1983 Deville D'Elegance, 62 Deville
    Nov 2013
    4
    Re: Utlimate goal
    I am not really sure why everyone is trying to treat this setup any different from say an 03-04 Cobra? Or even the ZR1 blower. The Cobra has DOHC, just like the Caddy, and it is almost the same CID, AND has a factory supercharger with nearly the same setup. Heat soak is always going to be an issue with ANY supercharger. There is always a normal process with every boosted application. Too many people try to skip to the end. Of course a whipple or better design s/c would be beneficial, but with a somewhat limited aftermarket and too many directions to follow, it just seems like the whole thing gets strung out in 9 diff directions.
    Just my .02 but its not rocket surgery.
  5. #49
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Re: Utlimate goal
    Quote Originally Posted by Loner View Post
    You should probably do some reading before you assume that we're all newbies. Many of us aren't.
    GizmoQ likes this.
  6. #50
    Nov 2013
    4
    Re: Utlimate goal
    I did read. Assuming goes both ways.
    I do appreciate how you skirted my actual points though.
  7. #51
    Feb 2009
    37
    1,894
    Re: Utlimate goal
    I did that because all the info is on this forum. I've done more testing and development on this car than anyone and to insinuate that I'm going about it all wrong is insulting. If you have something to add to the discussion, go ahead.
  8. #52
    Nov 2013
    4
    Re: Utlimate goal
    Its ok, ill just lurk some more and watch. It is all very interesting. I am sure there are others out there whom have done quite a bit as well, but they possibly have just not posted it up on a forum.
    You cant answer my direct questions with even a link?
  9. #53
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Re: Utlimate goal
    The cobra and ZR1 don't use a laminova intercooler...
  10. #54
    Nov 2013
    4
    Re: Utlimate goal
    So the ZR1 doesnt pass the coolant through blocks in the upper portion of the supercharger setup through a heat interchange brick which is similar to the way the STS-V charger is set up? Even the talking points of the "laminova" heat exchanger appear to be better than the blocks in the ZR1 charger.
  11. #55
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    I am sure you a wrong about this. Might be a reason why he creates the parts for this car when none else is.. I'd say that most likely constitutes you being a little off base.
    264WOODY likes this.
  12. #56
    Feb 2012
    Charlotte, NC
    338
    Re: Utlimate goal
    They are both air to water under blower units. That doesn't speak a thing about performance from one to another, nor with respect to upgraded cobra intercooler.
  13. #57
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,313
    Re: Utlimate goal
    What were the crucial points that Tim skipped? I didn't see any points made for him to skip.
    Regardless of application, S/C make heat. We get that. It's now a "how do you get heat OUT of it!" and that is what many here (Tim being one of them), have tried to solve, using methods similar to those other applications, and they don't seem to hit pay dirt.
    No one here has jumped to an end conclusion.
    I still stand by the point that running each of the 4 cores in parallel (vs. 2 in a series), would create the biggest benefit. The problem is, cost. With only 2,500 cars made with this engine, 3k if you include the XLR-V, your market of those interested is extremely small, and probably not worth the R&D to create the necessary components on either end of the intercooler, to make the change. That's not skirting anything. That's trying to find a solution that addresses the problem!
    Nimoch and 264WOODY like this.
  14. Remove Advertisements
