couple questions.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree1Likes
Cadillac STS-V Series Forum Discussion, couple questions. in Cadillac V-Series Forums; So I have two questions: What brand gasoline does everyone use? My tires are showing mad toe wear, is this ...
    ChurchSTSV's Avatar
    ChurchSTSV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V
    Oct 2012
    Chandler,AZ
    33
    369
    couple questions.
    My tires are showing mad toe wear, is this alignment or could it be something else?
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: couple questions.
    I use 93 no ethanol. I've had to resort to regular 93 non ethanol with no issues. Then recently I put some 93 from marathon in and i got a check engine light not too long after. Called onstar. They said
    Fuel control system reading not as expected
    P0174
    So I put my usual non ethanol gas back in and disconnected the battery touched cables together, reconnected, and haven't had an issue. Been a week and a half with a healthy amount of driving.
    I have a lot of toe wear too. Mine is alignment.
    Dave G is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Apr 2009
    42
    317
    I generally stick with Shell,Mobil or BP.
    I won't use Marathon. My wife had an issue several years ago after filling up at one and we've both sworn them off since.
    Sounds like alignment to me.
    Feb 2013
    Whitestone, NY
    28
    3,211
    So I take it something happened to make you ask about the gas?
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    Interesting about the gas, I've always use 93 octane from marathon in mine and never have had a problem. I always thought that marathon was one of the better stations. shows how much i know lol
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    Best I can get here in AZ is 91 and I mostly use Chevron.
    As for the tires, it is alignment. If you are using the stock settings have them changed. The stock setting kill the tires really fast. Try these.
    http://www.cadillacforums.com/forums...r-aligned.html
    I use them and my inner wear is gone. My tires in the front show even wear across the tire.
    Guy.Seminerio likes this.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thank you so much for posting a link to that thread. I'm going to go with these specs for my alignment. Although my issue is with wear on the outsides more so than the insides.
    If the marathon works, go with it. Google top tier fuel and make sure marathon sells too tier fuel.
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,317
    Usually Shell or BP 93 octane. Do you have a spectre intake? That was causing problems and I think P0174 was the result.
    If you have toe-in wear, then yes, you need tohave that adjusted.
    Feb 2013
    Whitestone, NY
    28
    3,211
    No mods. And I'm going to go with the specs in that thread. The seem proven enough for me. Waiting on the lowering springs before I do the alignment. Otherwise I do it twice. I just hope my tires make it to the day I get the springs.
    ChurchSTSV's Avatar
    Oct 2012
    Chandler,AZ
    33
    369
    I was just curious on the brand fuel everyone was using. Like it was mentioned, all I can get is 91. AZLOL
    I was just curious on the tire thing. I'm sure I will get an alignment once I slap new tires on her.
    06 STS Rob's Avatar
    06 STS Rob is offline Cadillac Owners Fanatic
    Automobile(s): 08 STS V, had 06 V6 STS
    Jul 2010
    Lake Elsinore,CA
    40
    427
    I can only get 91 here in CA... I run chevron and Costco mostly. I also get P0174 from time to time, in fact, I have that code right now... Tim C intake and plug in so I just figured that's what causes the cil to come up. I just clear it with my cheapie code reader and move on.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Wow. What is it with all this no 93 crap? A lot of gas stations here in NYC 89 is the lowest you can get.
    Rob do you think it's the gas causing the code?
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    48
    600
    i always use fuel with Techron in it to keep the injectors clean.Heres thats Chevron and Texaco--93 have never got a code
  16. #14
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,317
    Just an FYI, GM fuel system cleaner is relabeled Chevron Techron.
  17. #15
    06 STS Rob's Avatar
    Jul 2010
    Lake Elsinore,CA
    40
    427
    Quote Originally Posted by Guy.Seminerio View Post
    I'm pretty certain it's the intake...with having the intake and no tune, the code it coming up lean (too much air) I have Tim's plug in but I'm sure a real tune will solve the issue. Never had a code before installing the intake.
  18. Remove Advertisements
