Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Engine hot ac off
    iLuvEasy is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V Raven
    Oct 2013
    Houston
    34
    Engine hot ac off
    I got this message on my dash engine hot ac off and the engine temp gauge is not working has anyone experienced this?
    Berger 93 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS-V
    Feb 2007
    Schaumburg, IL
    317
    Re: Engine hot ac off
    Yup . . thermostat is bad . . typically it is stuck open.
    Oct 2013
    Houston
    34
    Ok just get one from autozone?
  5. #4
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    FYI this happened to me a couple of months ago. I pulled over and did a google search of the error message and the word "cadillacforums." Definitely tstat but some mentioned that for the time being disconnect and reconnect the battery. I did that, message went away and hasn't been back since. We're talking a few thousand miles later.
    After all, you do love easy.
  6. #5
    Oct 2013
    Houston
    34
    Well it did rain today so that could be the problem too
  7. #6
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by iLuvEasy View Post
    Hello iLuvEasy,
    I apologize that your engine temperature gauge is not working and you are experiencing this message on your dashboard. I see that you have gotten some great advice from the community. Please keep us updated on this issue and if you decide to take your vehicle to the dealership to address this issue, please feel free to contact us via private message. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
  8. #7
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,602
    Post #50 for this I think now lol.
  9. #8
    Oct 2013
    Houston
    34
    Thanks I disconnected the battery and it reset it self but I'm still take it to get looked at or a pressure check done on the radiator
  10. #9
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    Spend the $15 and get a new T-Stat. Take you about 30 minutes to replace it.
  11. #10
    Oct 2013
    Houston
    34
    Thanks bought one today
  12. #11
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Two 10mm bolts hold the housing down. don't worry about removing any hoses.
  13. #12
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    31
    261
    ALSO IS A UPDATE FOR THE ENGINE CONTROL MODULE FOR SETTING FAULTY P0128 WHICH IS THERMOSTAT DTC SETTING. i had same problem and found bullentin for installing latest update in the engine control module due to it could cause that message and dtc to set along with putting a new thermostat in mine. would have to take to a dealership less your around columbia sc i could help you out lol
  14. #13
    Oct 2013
    Houston
    34
    Gasket?
  15. #14
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    I didn't replace my gasket, it's a rubber o-ring in the shape on a number 8. weird i know. It took me about 2 hours to do mine, but i took off the two hoses to it and other various ones to gain access to the Tstat housing. I also removed the first part of the air intake, so I could get my fat hands down there. Oh and be careful oh hot coolant, this beast holds its heat for quite a while. And I used one gallon of premixed coolant. Dexcool of course.
  16. #15
    Oct 2013
    17
    I had the same problem. New V owner. Took it to my mechanic and he said just needed a reboot of the computer....$ 100 later. It went away for 5 days and them same error popped up. Read the posts in this forum and disconnected the battery posts as suggested and all is going good....... So far. My mechanic charged me $100 to reset the computer?????
  • You may not post replies
