CTS-V2 6 piston front calipers
Results 1 to 9 of 9
Cadillac STS-V Series Forum Discussion, CTS-V2 6 piston front calipers in Cadillac V-Series Forums; Is anyone interested in a swap kit? I can do the yellow calipers, pads, and CTS-V2 rotors drilled with our ...
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    I can do the yellow calipers, pads, and CTS-V2 rotors drilled with our six lug pattern for $999 plus shipping. Silver calipers are an extra $100 each for some reason. I can get those too.
    Stock wheels fit with these calipers.
    Only mod necessary is to drill the mount holes on the spindles out to 14mm from the current 12mm. If you wanted to put the stock calipers back on a bushing to reduce back down is all you'd need.
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Re: CTS-V2 6 piston front calipers
    I remember when the cts guys were doing this a while back. Is there an aftermarket swap rotor available with 6lug pattern?
    Feb 2009
    37
    1,895
    Quote Originally Posted by Fierofiend View Post
    You can get custom two piece rotors for $750 to $800. I would be using re-drilled stock replacement one piece rotors. The center bore is the important part and that is the same size as ours already.
    Angr-E1 is offline Cadillac Owners Member
    Automobile(s): 06STS-V
    Jan 2013
    17
    Has anyone tried to swap out the actual 6 lug hub for a 5 lug hub and adapt the V2 brakes to that? For example, swapping in the non v sts hub and redrilling or finding new rotors that fit. Only reason I would that is for wheel options because everyone knows how limited the selections are out there.
    Feb 2012
    Charlotte, NC
    338
    I think someone did that on the cts. Might have been a corvette hub.
    Feb 2009
    37
    1,895
    Or Camaro. They might be the same.
    Feb 2012
    Charlotte, NC
    338
    Custom rotors are probably easier/cheaper than hubs, as you don't have to factor in cost of wheels. I wonder if there are any other 14.5" (370mm) rotors that might be an alternative. I'm not against drilling, I've redrilled vette rotors to 5x100 for the fiero, but the 5 hole patterns didn't overlap.
    2007blackbty is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V
    Mar 2013
    sussex, wi
    40
    213
    Any update of rotors that don't need to be re drilled or blanks.what about back calipers do they bolt on.just for color matching.instead of powder coating?
    Feb 2009
    37
    1,895
    Vipers are the only cars I know of with the same bolt pattern we have. They currently have the same size brakes as we do so that's no help.
    Rear calipers are the same.
  12. Remove Advertisements
