2006 sts-v pull dtc s
Results 1 to 5 of 5
Cadillac STS-V Series Forum Discussion, 2006 sts-v pull dtc s in Cadillac V-Series Forums; Is there a secret way that I can make my car give me the dtc codes ? I had an ...
    Rob Bernard is offline Cadillac Owners Member
    Automobile(s): sts-v
    Aug 2013
    Is there a secret way that I can make my car give me the dtc codes ? I had an older seville mid 1990 s and I could press certain buttons and the codes would show up on the display.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,529
    Re: 2006 sts-v pull dtc s
    nope, that went away in the seville/deville lines.
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    Quote Originally Posted by Ludacrisvp View Post
    Ah, I miss that feature with my Seville and Eldorados. Strange GM put that feature in a vehicle least likely to be used by their owners.
    A cheap CAN enabled code reader will do the trick. I bought one to use before getting the CANdi module for my TechII. Still comes in handy for my non-GM vehicles.
    Aug 2013
    Ok thanks for the info What is CAN enabled
    wake's Avatar
    Sep 2003
    Stafford, VA
    804
    Quote Originally Posted by Rob Bernard View Post
    Most scanners you buy in the parts stores today are CAN enabled, CAN is the standard that started around 05 for some vehicles, 06 for most of the vehicles. Prior to that GM used the Class II data bus. All the vehicles systems communicate over the data bus between the different accessories and control modules.
    Just look for CAN enabled/compatible when shopping for one. I'd be surprised if anything produced in the last few years wasn't CAN enabled.
  8. Remove Advertisements
