Front Parking Lamp
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, Front Parking Lamp in Cadillac V-Series Forums; One of the front parking lamps went out. (The little dot in the headlamp assembly.) Has anyone replaced these with ...
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Front Parking Lamp
    One of the front parking lamps went out. (The little dot in the headlamp assembly.) Has anyone replaced these with LEDs? If so where did you get them and what size/type?
    Last, any advice on taking out the old one and installing the new?
    Thanks.
    todrules is offline Cadillac Owners Fanatic
    Feb 2012
    Milwaukee, WI
    115
    Re: Front Parking Lamp
    You have to remove the headlight assembly, meaning bumper cover has to be dropped. It doesn't have to totally come off, but it does have to be dropped. I just changed mine to I believe 194 LED's. I had the bumper cover off installing timc heat exchanger. One of mine was burnt out since I bought the car. I did have an issue one of the tiny little tabs broke off. I just epoxied it together, if they burn out from now on it's on oh well I guess.
    Ok I checked the old bulb and no number on it, The LED's I have aren't labeled either. Either way it's the same bulb as the interior lights. It looks like a 194.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks
  5. #4
    2007blackbty is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V
    Mar 2013
    sussex, wi
    40
    213
    There's a door on side of headlight housing grey in color with 1 screw.take that off pull out the hid ballast and reach in and replace bulb.194 sounds right for part number.be carfull putting that door back on it has a gasket.screw that up and you'll get water in housing.which I did and fried my ballast.but it took my buddy 5 minutes.very easy
  6. #5
    Feb 2012
    Milwaukee, WI
    115
    Yes definitely make sure you get the gasket seated right for the ballast or that could be an expensive mistake.
  7. #6
    Feb 2013
    Whitestone, NY
    28
    3,211
    So still bumper removal required?
  8. #7
    Feb 2012
    Milwaukee, WI
    115
    That's the only way to get the headlight housing accessible. You don't have to totally remove it, you can leave the headlight washers connected and drop it down a tad to access 3 bolts or nuts for the headlight assembly. Believe it or not our cars bumper cover is pretty easy to take off. There are 2 10mm bolts accessed through the fender liner and a ton of plastic push rivets.
  9. #8
    Feb 2013
    Whitestone, NY
    28
    3,211
    I know exactly what you're talking about. Thanks again.
  10. #9
    Mar 2013
    sussex, wi
    40
    213
    To replace ballast at dealer gotta buy whole housing for 1, 000.I bought use ballast off ebay for $70.hopfully it last
    Just go threw side door and be done in 5 minutes .no bumper removal
  11. #10
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    31
    261
    i pulled the headlights off the vehicle and have replaced the riding lights in the bottom corner of headlights with leds they barley fit just b/c they are a little thicker but i got them in and look great i got led fog light bulbs off this site as well did them while i had bumper off http://store.ijdmtoy.com/ little expensive but have had a couple people recomend this site and haven't had any problems with bulbs and they look awesome in the car
  12. #11
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks
  13. #12
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,312
    I removed the bumper cover.
  14. Remove Advertisements
