Cadillac STS-V Sport Springs back in stock early September!! - Page 11
Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 151 to 160 of 160
Like Tree22Likes
Cadillac STS-V Series Forum Discussion, Cadillac STS-V Sport Springs back in stock early September!! in Cadillac V-Series Forums; The noise on the front got worse as it got colder in Texas I heard occasionally in summer it really ...
  1. #151
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    Sep 2011
    San Antonio Texas
    38
    148
    The noise on the front got worse as it got colder in Texas I heard occasionally in summer it really annoying. Can't really described the noise but u hear it over the bumps. The bracket they are talking about is above the upper control arm it has a bushings on the top of it. I think, so I order the bracket it part of the upper control arm assembly. I thought I need strut guess not. Anyway got my springs n I bought new strut and the upper control arm. Next Saturday will install it and the valve cover gaskets. I took a picture but can't display it for y'all.
  2. #152
    Cadzilla8's Avatar
    Cadzilla8 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac STS Northstar V8
    Feb 2013
    NY
    247
    So I installed my springs Thursday night wasn't too bad, the rears are small and not really crazy about how they are totally free if you jack up the rear end (even though it made installation easy)
    First impression: wheel gap is gone and looks great! Handling has noticeable improvements and you can feel that it is quite a bit stiffer but not uncomfortable. Looking around the car the rear "appears" lower than the front but I think the large front fenders and more subtle rear fenders make it look like rear is lower now that they are a lot closer to be level than rear being higher.
    I also notice the front and rear had extra negative camber and hoped the alignment I got on Saturday would fix that. Well it didn't and I plan on going back this week to see what I can do to get 0 camber. You guys who already got springs on and aligned any help? Do you still have negative camber? It looks more than it should be and I just put fresh tires on and I would rather not wear them out prematurely
  3. #153
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Cadillac STS-V Sport Springs back in stock early September!!
    Glad you like them. The rear comes down 1.25 in and the front .75 in with these springs so the rear will lower more than the front.
    I went with these alignment specs.
    http://www.cadillacforums.com/forums...r-aligned.html
    Printed them out and gave them to the people doing the alignment.
    About two weeks later I had them aligned again and sure enough with the car settling there was a lot of adjustment necessary to get back to these specs.
    Next, with these springs, those alignment specs will not be possible to duplicate to a tee. Not sure the details but it had to do with the camber. So the guy came as close to those specs as possible. I too am on new tires so I care about how they wear. We'll see.
  5. #154
    Cadzilla8's Avatar
    Feb 2013
    NY
    247
    Quote Originally Posted by Guy.Seminerio
    Glad you like them. The rear comes down 1.25 in and the front .75 in with these springs so the rear will lower more than the front. I went with these alignment specs. http://www.cadillacforums.com/forums...r-aligned.html Printed them out and gave them to the people doing the alignment. About two weeks later I had them aligned again and sure enough with the car settling there was a lot of adjustment necessary to get back to these specs. Next, with these springs, those alignment specs will not be possible to duplicate to a tee. Not sure the details but it had to do with the camber. So the guy came as close to those specs as possible. I too am on new tires so I care about how they wear. We'll see.
    Thanks for the advice with those specs, I have a STS with standard suspension and shocks not sure if it would be different between STS and STSV and rear camber is too negative (tilted in on top) and it doesn't look right so hopefully the shop will be able to get this as close to correct as possible
    EDIT:Shoot reading through that thread it's pretty clear the standard STS specs are much different
  6. #155
    choigilligan is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Aug 2010
    195
    Quote Originally Posted by Carlosg
    Took my ride to dealer had them check a noise coming from the front suspension and a oil leak. This what they told me valve cover gaskets and on the front suspension need upper control arm bracket.
    What's the part number for the upper control arm bracket? I have that same sound and need to replace mine.
  7. #156
    Carlosg's Avatar
    Sep 2011
    San Antonio Texas
    38
    148
    So I did lower my car put new strut and the new upper control arm they were sold as a assembly the part #gm 25847857 gm 25847858 there is core charge. Could not really tell about the noise. Did not drive the car that much took to shop for collision repair someone back into my wife a month ago. Try to post picture but could not get it.
  8. #157
    Carlosg's Avatar
    Sep 2011
    San Antonio Texas
    38
    148
    [171554[
  9. #158
    TheOmen is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V, The Omen 69 Camaro
    Dec 2013
    Bay Area, CA
    32
    19
    sooooo yea...about that other batch of springs that were being made?
  10. #159
    Feb 2013
    Whitestone, NY
    28
    3,211
    Did you try calling d3?
  11. #160
    Rboughne1's Avatar
    Rboughne1 is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-V: CAI, HE, 2.4" Upper, TB & S/C Port, Headers, Exh
    Jul 2014
    Jersey
    663
    Quote Originally Posted by Cadzilla8 View Post
    Did you install yourself? I plan on putting mine in tomorrow with a friend. How long did it take? And those rubber pieces that came with them where does the large think rubber stoppers go and where does the thin ones with washers go?
    I'm thinking the thin rubber spacer went below the upper shock mount, above the plastic cover, and that both rubber spacers (one factory & one aftermarket each side, stacked) , went on top of the mount with the newly provided metal washer under the nut?
  12. Remove Advertisements
