Motor sounds when door is opened.
Results 1 to 6 of 6
Cadillac STS-V Series Forum Discussion, Motor sounds when door is opened. in Cadillac V-Series Forums; Every time either front door is opened there is an electric motor sound with five clicks from the drivers' door, ...
    hiltonny is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2008
    171
    Every time either front door is opened there is an electric motor sound with five clicks from the drivers' door, is this normal?
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,317
    Re: Motor sounds when door is opened.
    It could be your seat, mirror, and other things adjusting to the appropriate remote with your saved settings, if you're just walking up to it and opening the door through the proximity sensor (not unlocking it with the keyfob button). Also if you have the navigation screen tilted, it could be readjusting that too.
    06 STS Rob's Avatar
    06 STS Rob is offline Cadillac Owners Fanatic
    Automobile(s): 08 STS V, had 06 V6 STS
    Jul 2010
    Lake Elsinore,CA
    40
    427
    Yes, once the FOB is detected the car starts to "wake up".
    The problem with this for me is when I'm on the phone and open the trunk. Although the car isn't ON, it will connect through the bluetooth and interupt my call...
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,317
    Can you hear me now?
    Apr 2008
    171
    It was the outside mirror trying to adjust settings as CMNTMXR57 suggested but it was set all the way to the left and must have been hitting a stop. I adjusted the mirror to the right a little and that fixed it.
    CMNTMXR57's Avatar
    Feb 2009
    44
    1,317
    Things go whacky on this car a lot. Occasionally mine sets a module communications code (I forget what U code it is), and all the sudden I go to start the car up and I'm being crushed into the steering wheel and windshield as the power seat tries to go all the way forward...
    I go clear the codes, and it's fine.
  9. Remove Advertisements
