Please give me good news - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Cadillac STS-V Series Forum Discussion, Please give me good news in Cadillac V-Series Forums; Yeah, I've never seen a wheel bearing bad enough to cause a shake either. Only way I could tell other ...
  1. #16
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    Re: Please give me good news
    Yeah, I've never seen a wheel bearing bad enough to cause a shake either. Only way I could tell other than the noise was by feel when turning it by had with the wheel off. Sometimes it's impossible to figure out which side is bad from the sound alone. That's why you have to feel.
  2. #17
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    my wheel bearing caused a shake. didn't make MUCH noise, but cause annoying vibration. went to autozone, got the cheapy $50 one and it went away. now when I replaced the pads on the driver side the bearing was grinding, so itll be replaced soon enough. only takes 15min. lol
  3. #18
    terrydactul is offline Cadillac Owners Member
    Automobile(s): Sts V
    Nov 2011
    40
    Thanks everyone for the input so far... Do you guy's think based on my problems that my car is safe to drive?
  5. #19
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    I would be concerned its a bad cord in a tire and that can go a any time. If you are 99.5% shore it's not the tires you should be fine to drive it.
  6. #20
    Nov 2011
    40
    Guess ill buy 2 new front tires and see where that gets me, i'm transferred 3.5 hours from home for work for the next 4 weeks making the drive back home for the weekends. I need this shake gone before something bad happens while I'm out of town.. Is it strange that it's been to two different shops( Cadillac and Firestone) and no one has said "hey your wheel bearing is bad" or something along those lines? I paid cadillac over 200 dollars to "diagnose" the issue and they came up with bent wheels, and they also did a full vehicle inspection and mentioned nothing to me other than the front wheels being bent.
  7. #21
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    We're these the tires that were on the bent wheels?
  8. #22
    Dec 2011
    Missouri
    31
    894
    im currently driving on a slightly bent rear rim. just don't have time to deal with it currently, are there any long term issues with doing that mad?
  9. #23
    Nov 2011
    40
    Quote Originally Posted by 1madstsv View Post
    Yes they are
  10. #24
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,317
    9 times out of 10, you will hear a wheel bearing/hub assembly going south and if bad enough, poor fuel economy. It'll buzz/whirr as you're driving.
    I still say tires, but instead of paying for a new set, do you have any warranty left on the ones you have on currently (the Michelin's). Michelin is pretty good about warranty and if anything you could get some pro-ration.
  11. #25
    06 STS Rob's Avatar
    06 STS Rob is offline Cadillac Owners Fanatic
    Automobile(s): 08 STS V, had 06 V6 STS
    Jul 2010
    Lake Elsinore,CA
    40
    427
    Something to concider....
    Wheels don't just bend on their own. If you had a bent wheel or even concern of a bent wheel (i.e. dealer told you it's bent) think of this. If there was an impact hard enough to bend your wheel, chances are it damaged the tire that was on the wheel as well. If all your bushings look good I would certainly go with buying a new set of front tires or as stated above, try to get a warranty replacement on your tires.
  12. #26
    Nov 2011
    40
    The thing is I never did anything to the car to bend the wheels, I'm not sure if I just hit a pot hole or something, would the wheel being bent cause uneven wear causing a shake or would it have to be bending the wheel caused a warped tire?
  13. #27
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    I think you hit some thing in our on the road some times it's the small holes that get you. And it bent the wheel and messed up the tires.
  14. #28
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    31
    261
    well coming from a technicians view at a gm dealer you def need to do as boomys10 said and need to take wheels and tires to dealership or place that can roadforce tires, i have had ton of vibration issues that you can balance the tire all day and as soon as you roadforce tires you will find your problem. high spots in the tire need to be matched to low spot in wheel or either tires replaced if forcematching isn't able to be performed which the machine will tell you. def would recomend having that done tire with excessive runout will cause all kinds of vibration issues.
  15. #29
    Nov 2011
    40
    okay guys, after the initial bent front wheels the shake continued after I took it to Firestone for the dismount/mount, balance and, alignment it continued to shake.. I took it to the dealership again and to my surprise Firestone left off half the required weights.. The car is now running smooth as ever, thanks everyone for your input. I'm now selling it due to my need for a truck, if there is anyone interested in a 06 V hit me up
  16. Remove Advertisements
