Intercooler pump
Results 1 to 11 of 11
Cadillac STS-V Series Forum Discussion, Intercooler pump in Cadillac V-Series Forums; When does the pump run? Anytime the engine is running?...
    cmross97's Avatar
    cmross97 is offline Cadillac Owners Fanatic
    Automobile(s): 06 STS-V, 97 Camaro SS 490rwhp, 02 Jeep GC
    Mar 2005
    113
    Intercooler pump
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,895
    Re: Intercooler pump
    yes. they fail all the time.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    What are the symptoms of a failed intercooler pump? Overheating?
    Feb 2009
    37
    1,895
    Sluggish performance due to high air temps and timing reduction.
    Pull a hose off the intercooler lid while the engine is running if you think your pump is bad. If no water comes out it's not working.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,662
    Or you can pull the cap off the fill tube by the battery and and check for flow. There should be a good flow. When I upgraded mine I went from a trickle to a quick flow.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    If its not working try unplugging it and cleaning the connection. Mine stopped working and I did that and it's still working 1 year later.
    2007blackbty is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V
    Mar 2013
    sussex, wi
    40
    213
    Disconnected hose off blower nothing came out only out of the metal line.just trying to see if ic pump is working.car runs fine but I see no movement in ic fill cap and can't hear pump running.im no mechanic .is pump covered under gmpp? Is coolant suppose to come out of hose if disconnected while car is running?
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    Yes, if you pull a line off the S/C there should be a stream of coolant come out. If there is no movement with the engine running and the cap off then yes its dead. Not sure if GMPP will cover that but it should.
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    31
    261
    so put the timmy c heat exchanger on mine today always wondered y my car was getting beat by cars it shouldn't well today when i went to bleed air out the chargers cooling system i commanded pump on and got nothing tapped on the pump and started working anybody know where a good aftermarket pump without having to do a lot of mods could be purchased new one from gm is 338 bucks my cost lol
    PGA2B's Avatar
    Jun 2009
    USA
    2,662
    The Jabsco is really not that hard to put in.
  14. Remove Advertisements
