Burping heat exchanger
Results 1 to 5 of 5
Cadillac STS-V Series Forum Discussion, Burping heat exchanger in Cadillac V-Series Forums; I was wondering if any of you guys have a good system for burping the most amount of air out ...
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    I was wondering if any of you guys have a good system for burping the most amount of air out of the heat exchanger cooling system? I have a TC fab heat exchanger upgrade. Thanks
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Re: Burping heat exchanger
    Just keep taking the cap off the fill tube by the battery and fill as needed. It will take a few drive cycles to get it all out. Took me about a week til I was happy.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,892
    Yep, that's the only way to do it. Don't take the rectangle cover off the top of the intercooler lid. It does vent the air nicely, but the o ring will never seal again. If you want to replace the o ring go ahead and remove it, just be ready.
  5. #4
    Zzapp's Avatar
    Zzapp is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS-V mine and 2010 CTS wife's
    Jan 2012
    So. Cal
    112
    I burped mine by taking the rectangle cap off and I did not have any sealing issues after... I guess thats hit and miss... Harbor Freight does sell an "O" ring set for cheap 10-15 bucks unless its onsale then its about $8
  6. #5
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    In a GM Service Dept
    44
    1,312
    I've had mine off several times and have had no issues. Technically during refill, you're supposed to open/take out the vent nut, down on the radiator itself (on the drivers side) on top of the stock intercooler if I recall (which is irrelevant in your case as you don't have the stocker), and fill until you get fluid to that point. Cap it off, cap off the rectangle cap, then fill the resevoir tube until it's to the top, and then top off as necessary. It may actually take a little while. I'm still burping mine from the flush about a month ago. It helps if you cycle the intercooler pump. This can be done with a Tech 2 (look for the CAC sub-menu. CAC stands for "Charged Air Cooler" in GM speak), and you can manually toggle it (the CAC pump), on/off, or you should be able to, by running the engine.
    The PITA is the retarded design of the opening UNDER that rectanglular cap, and may be the reason one thinks you're not sealing because you probably spilled a bit trying to fill it there. You have to pour the coolant in at a dribble, otherwise you'll overflow it because there is no room inside that hole to quantity fill it. I end up wrapping a towel around the bottom of a small funnel, then slowly pour it in, and still occasionally have a little spill over.
  7. Remove Advertisements
