Traction Control Keeps Coming On
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, Traction Control Keeps Coming On in Cadillac V-Series Forums; My traction control keeps coming on when I go over bumps at low speeds. ---------- Hit send before I could ...
    choigilligan is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Aug 2010
    195
    Hit send before I could finish. Basically the traction control is intervening at times where I am at very low speeds, under 10 mph, I might be entering a parking lot and the traction control will retard the ignition for no reason. Has this happened to anyone else.
    It generally occurs when I'm not on a flat road, but I'm literally coasting, not applying any throttle and the TC will come on.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Re: Traction Control Keeps Coming On
    Sounds like a speed sensor is going out. Get someone to scan it with a scanner that can display all 4 wheel speed sensors at once. I bet one of them is getting flaky.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by choigilligan View Post
    Hello choigilligan,
    I apologize that you are experiencing your traction control coming on at low speeds with your STS-V. I do see that you are reaching out to the community to see if they have experienced this as well, but I wanted to know if you were thinking about taking your vehicle into a dealership to see if they would be able to diagnose your concern. I would like to assist you in working with them if this is the route you would like to take. Please private message me if you would like my assistance. Thank you very much for your time.
    Gregory W.
    Cadillac Customer Care
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    What size tire are you running and is the tread very low?
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    31
    261
    sounds like a connection or hub bearing/wheel sensor could be bad, if hub in front or rear has play in it when you turn its going to create excessive space at abs sensor in hub need to pull codes or have taken to delership or somebody that can pull abs dtcs out. make sure right tire sizes are on vehicle as well that will cause traction light to come on also.
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    if I run a 275/35/19 in the rear will that mess with my traction control?
    Feb 2009
    37
    1,894
    Quote Originally Posted by boomys10 View Post
    I think it will. That's a decent amount shorter than stock. It should work if you run a 255/40/18 in front.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    Yep there's your problem. My old car ran a 295/30/19 and it was fine till the tread wore down. Now the new owner says its doing the same thing as your car.
    Aug 2010
    195
    I've got stock rims and tires, w basically new Cooper Zeon's. definitely driven them less than 3000 miles w them. I put about 6,000 miles a year on the V. Anyone got a scanner in MA that can check this out.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    I did not even look to see who posted that my bad. As for scanning unless it's tripping the cel I don't think there will be a code.
    Aug 2010
    195
    Had it scanned, nothing. I did notice it only happens when I'm turning left over curbing at low speeds. Any other ideas.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    Check the rear end fluid level. It might be low our old and not releasing the dif clutch and keeping the tires locked. Like a drag car with a welded rear. Some thing to look at.
  15. Remove Advertisements
