My 07 has only 16500 miles on it and I have put 3K on it since I bought it 2 months ago. What maintance should I have done other than the oil change? Should I flush the trans and change supercharger fluids? I am just wondering what else I should have done at the dealer, the car sat in a garage for most of its life. Any advice?
This car is all stock no mods have been done to it.
According to the manual transmission service happens as early as 50k miles. I had mine done at 52 and change. Unless the car sitting does something to the fluid to make it age prematurely you've got a long way to go for that.
tranny fluid does age out if it were me id change the tranny,rear end, cooling system, and perhaps brake fluids--dont know about SC.I keep my cars at least 10 years--and do these fluids at 7--just me--I bring it to a trusted oil change place near me--its a Texaco brand---id leave the SC up to the dealer--The oil change spot is like half the dealer,and i can watch them do their stuff-f your ehere in Atl i can tell you which one i use
Well I am kind of concerned how it is shifting. When I roll to a stop sign and stop, once I put my foot on the gas again there is a lag in power and sometimes it catches hard on the first gear. Then second gear hits hard too. But it seems if I keep the gears engaged they shift fine, also they shift fine in manual too.
It just seems the motor rpm is up before the gears engage when coming off of a stop sign or a stop.
Transmission tuning on this car does wonders. A lot of members have a "shift flare" issue. But tuning this car should be done by someone with knowledge of the torque management and traction control this car is equipped with.
sounds likeyou have it set for compettive driving mode--which makes harder shifts--Check the manual and see how the different modes are set--Id still change all thenfluids--its cheap insurance
Don't you have to actively put it into competitive driving mode? In other words I doubt he'd be in that mode without knowing it. Also never noticed it affected shifting. Always thought it was suspension and steering.
No that's when you put it into sport shifting mode. Slide the shifter to the right and it goes into sport shift mode which holds gears longer. As far as I know competitive driving mode doesn't mess with the tranny.
No, this happens when I am putzing around my neighborhood, it is not in sport or manual or competitive driving mode. I realize that everything is based off of mileage. That is why I am asking the questions here because the car has very low miles but is 6 years old and has sat most of its life in a garage. On average the car was driven 2250 miles a year until I bought it 2 months ago, that adds up to a lot of sitting time. Just because there are low miles does not mean the best thing for it is to act like all the fluids are great and brand new.
I am wondering how much of the "not regularly changed fluids" I should change that can get pretty pricey.
When I'm going at certain speeds, then I let off the gas, then get back on it, it'll sometimes slam into gear. I have a shift flare issue under moderate acceleration when shifting from 3-4 at approximately 25-30 mph and I've discovered it is MUCH more likely to happen the first couple of times I do it. In other words something is "warming up" and preventing it from happening later on in the drive.
Guy, I get that 'slack' thing only in 3rd gear. If I'm in slow moving traffic where I'm off the gas then on again, it seems like there is play or something that gets taken up as soon as I touch the gas and I feel a bit of a 'jerk'. I took it to the dealer a while back to have checked out and they said it was normal. I checked the rear diff bushing and it was fine. I live with it.
I wish a GM tech or engineer would give a full explanation of what this is. I've never really experienced it before and with so much torque in these motors it just 'feels' wrong. I got the same explanation that you did. "It's normal the diff is fine." I actually got a trans tune from Jesse (wait4me) and it totally eliminated the shift flare and it feels like it nearly eliminated the "slack" feeling. I don't notice it like I used to...then again my commute has changed and I have less of that 25-30mph on-and-off-the-gas driving; so one could be completely unrelated to the other.
Either way, those with shift-flare, go get a transmission tune. Jesse is probably the best in the country with these transmissions - dude works wonders
Yep you describe it perfectly. Haven't checked to see what gears it happens in. Ill investigate, but I had a feeling it was normal. It happens in a lot of cars. It hurts me inside everytime it happens though.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
