Quick question
Results 1 to 7 of 7
Cadillac STS-V Series Forum Discussion, Quick question in Cadillac V-Series Forums; Are the front ends of these cars aligns me or are they set from the factory? The reason I ask ...
    wiz321654 is offline Cadillac Owners Member
    Feb 2013
    30
    27
    Quick question
    The reason I ask is bc my sts v ate the very very very inside of my tires up while the rest of the tire has ~60 percent tread. The car is still under full warranty from Cadillac an I am wondering if anyone else has had a issue with this? Thanks for any input!
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    Tire pressure may be the cause.. How much you run per tire? I run 30 to 32
    Feb 2013
    30
    27
    34-36 all the way around.. Over inflation would be in the center... They are worn on the very outer edge... Camber issues... Is the camber adjustable?
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    Re: Quick question
    I had to replace the bushings and ball joint on mine. it was the same conditions as yours. I would take it to the dealer and tell them to replace those parts since its under warrantee still.
    Feb 2013
    30
    27
    It just sucks bc those tires still have easily 60 percent tread on them... Are the front ends at all adjustable or are they non adjustable( camber wise)
    indabackofdalac is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V (present), 2004 DHS, 2000 & 1981 Eldorado (past)
    Apr 2013
    Manchester, NH
    11
    Re: Quick question
    When I got new tires, the stock run flats (yuck) had very similar wear... especially the front right. From what I read at the time, it is pretty normal for these. Inside edge was almost gone, outer 5/6ths of the tire looked nearly new. Had a 4 wheel alignment done @ 43k when I got new tires, and they did indeed adjust the camber... but, they couldn't get the front right all the way in spec, and recommended some sort of kit to finish getting it right. Since it was a marginal amount it was off by (and I didn't like the idea of the hassle of going to a mechanic to get it done then going to get another alignment), I never ended up doing the kit. Just my experience.
    Dec 2011
    Missouri
    31
    894
    Re: Quick question
    mine was the same. its .1 out of alignment on the front with the new parts. however its 1.4 on both sides instead of 1.3 *which would put it in the green, so im completely fine with it.
  10. Remove Advertisements
