Jabsco pump Install
Results 1 to 14 of 14
Cadillac STS-V Series Forum Discussion, Jabsco pump Install in Cadillac V-Series Forums; Taking a short break figured i would post a few pictures so far Fairly straight forward so far. Took me ...
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    Jabsco pump Install
    Taking a short break figured i would post a few pictures so far Fairly straight forward so far. Took me about 30 to 45 minutes to get stock pump out. Now I'm cutting the old pump bracket and fitting jabsco pump to that bracket. I'll post more pictures in little bit
    AriGold. is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Jan 2011
    Tulsa, Oklahoma
    143
    Re: Jabsco pump Install
    Nice job! Did you add any extra support on the factory bracket for the new pump? Jamie (PGA) had told me the factory groumet may end up breaking over time. The new pump is heaver so I added some support.
    http://www.flickr.com/photos/bobbynot/9087529692/
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    I think it was not a support issue but a dry rot issue on the part of the Jabsco grommet.
    todrules is offline Cadillac Owners Fanatic
    Feb 2012
    Milwaukee, WI
    115
    My question would be why would you be using a Sharkbite fitting? Those are specifically barbed ends for PEX. I would honestly recommend a standard male pipe X hose barb type. The barbs for PEX are made to be crimped, not for hose clamps.
    Automobile(s): stsv
    Mar 2013
    491
    I didn't realize that. I went to the local home depot, told the guy what I was trying to do. I brought the pump in with me for reference. He said this is what I was looking for... I'll be making another trip to home depot tomorrow for some different ones.
    Jan 2011
    Tulsa, Oklahoma
    143
    Quote Originally Posted by PGA2B View Post
    I say breaking, What I meant was rot like Jamie said. That's why I added the extra nut and bolt.
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    I wouldn't worry about that fitting, not worth the hassle of rebleeding the IC.
    Feb 2012
    Charlotte, NC
    338
    Did you finish up the install? Any more pictures?
    Automobile(s): stsv
    Mar 2013
    491
    Yes installed finished. I'll post more up this weekend when I'm back in town.
    Feb 2012
    Charlotte, NC
    338
    I did a bit more work on mine today. Here are two pics showing the bolts that need to be removed so that the impeller housing can be rotated. I was a bit unsure how that worked, but once I removed the two screws, i realized there is another set of holes 90* apart. I either missed that detail, or no one was really too clear on it. I just wanted to point it out for others that may reference this.
    Also, be careful removing the screws that hold the bracket on. I had one get caught inside the frame and it was a real pita trying to fish that thing out of there.
    Feb 2012
    Charlotte, NC
    338
    Well I guess I screwed up those links. I'd fix them, but I can't edit. Here are more pics of my install...
    47 Che V is offline Cadillac Owners Member
    Automobile(s): 47 Chevy V power driveline
    Mar 2012
    Goodrich Mich.
    28
    Inner cooler tubing and hose size must be of what size and capisity (volume) to properly cool super charger.
    Automobile(s): stsv
    Mar 2013
    491
    I reused stock hoses
  16. #14
    Feb 2012
    Charlotte, NC
    338
    I also reused stock hoses. The way I mounted my pump it was really close to the power steering cooler line and also the IC hard line. The picture makes it look closer than it is, but something to keep an eye out for.
  17. Remove Advertisements
