limp mode
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree1Likes
Cadillac STS-V Series Forum Discussion, limp mode in Cadillac V-Series Forums; car is now going into limp mode. we replaced the wheel bearing Monday and the car ran fine all of ...
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    limp mode
    car is now going into limp mode. we replaced the wheel bearing Monday and the car ran fine all of Tuesday, when I left work to drive home it was low on gas (not empty only took 14gals to fill up) left the lot came to a stop and the car completely died and said engine power reduced in display. shut it off, restarted still in limp mode got to the gas station about a mile up the road, (took forever!!) unplugged neg battery and filled up gas. drove home no issues. remote started car this morning, it shut off bc I was running slightly late. restarted it backed out of drive way and made it all over 1/10 of a mile before the first stop sign, car died AGAIN and displayed same message. pulled in neighbors driveway disconnected neg battery and restarted car, cleared the limp mode message and made it to three driveways up to the next stop sign and the car died AGAIN AGAIN. backed into another neighbors driveway disconnected neg battery and restarted car. drove fine the 10mile drive to work, with many stops in between. any ideas what could be causing this? I have to get home and im sure it wont throw a code when I can make it to a parts store to have codes pulled.. (I need to buy a scanner just cant right now)
    Dave G is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Apr 2009
    42
    323
    Re: limp mode
    Sounds like bad gas to me. And not the kind you get from too much curry.
    Dec 2011
    Missouri
    31
    894
    Re: limp mode
    that would cause limp mode? I got it from shell.. and its 93.
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Feb 2007
    Naperville, IL
    393
    Re: limp mode
    Not sure about the gas - he said it died the first time BEFORE he filled up. Sounds like a bad injector.
    Dec 2011
    Missouri
    31
    894
    Re: limp mode
    also, this just started, the car idles fine with no issues at all. even when started with that reduced power message it will rev up fine. only shows hates me when its moving. lol
    Dec 2011
    Missouri
    31
    894
    Re: limp mode
    p2135 is the code its throwing. someone advise please.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Re: limp mode
    looks like a throttle body code. Either that or the pedal.
    Dec 2011
    Missouri
    31
    894
    Re: limp mode
    pedal? like gas pedal?
    kbf250 is offline Cadillac Owners Member
    Automobile(s): 06 STS-V
    May 2010
    60
    82
    Re: limp mode
    p2135 refers to throttle position sensor.
    DennisW is offline Cadillac Owners Member
    Automobile(s): '08 STS-V
    Apr 2012
    San Antonio, TX
    7
    Re: limp mode
    I had the same intermittent issue on my '07 duramax. Couldn't wait for the solution so I replaced the pedal and wiring to the PCM in one shot. 2 years and 40k miles, no more issues.
    Feb 2009
    37
    1,897
    Re: limp mode
    Quote Originally Posted by kbf250 View Post
    There are two position sensors in the throttle body and two in the pedal. They all have to match. It sounds like one of them is not working properly. It could be a wiring issue but that is not terribly likely. I've seen it before on a car that had some damage to the engine harness. One of the throttle pedal wires was broken where it went into the computer.
    Quote Originally Posted by DennisW View Post
    The duramax doesn't have a throttle body so that is not necessarily a good indicator of what this problem is.
    Dec 2011
    Missouri
    31
    894
    Re: limp mode
    tb is ordered, should be in mid next week, slightly pissed about that since the one in the car is only a few months old currently. the company I ordered it from is warranting the last one but had to buy another one and have it shipped then ship the old one back and ill get my refund. wish they could be found local, damnit. also, when I started tearing into removing everything I noticed the coupler from the timmyc intake was slightly loose on the tb. from what I have read that could cause it, also, there is some black sticky shit around the tb blade, that also could cause it. that will be cleaned tmrrw when my friend brings some tools over since my old roomie took mine and I don't have half my stuff anymore. where can a pedal be purchased, haven't called the dealer bc I don't feel like paying, im sure, 500 for something that can be had online for 100 or less.. thanks for input timmyc. the tb will be replaced first, if that doesn't fix it, the pedal is next. the car now has 91000 on it, been slightly thinking about trading it in on something else (new cts-v or z06 vette, maybe a gen 1 cts-v..) but this thing is becoming a pain in the ass, guess I have to start being easier on it now.
    Apr 2012
    San Antonio, TX
    7
    Re: limp mode
    Quote Originally Posted by TimmyC View Post
    Good call for Tim, I sometime interchange pedal and throttle due to work. The new diesels do have a throttle to assist in cleaning (regenerating) the DPF.
    My intention was to say that for how unlikely a wiring harness issue might be, I have found them to be an issue that creeps up in increasing frequency with newer generation cars. Just something else to look at; good luck.
  16. #14
    Feb 2009
    37
    1,897
    Re: limp mode
    Very true. I saw that your main point was that it could be pedal or wiring but I was and still am thinking that it is more likely to be the throttle body so I wanted to put that info out there.
    Interesting that the diesels have throttle bodies now. I would never have guessed!
  17. #15
    Dec 2011
    Missouri
    31
    894
    Re: limp mode
    so here it what we did. took the intake off, took the tb off and cleaned the tb (not really dirty at all). did notice the timmyc intake was rubbing on the back of the supercharger slightly, which after inspecting we learned had rubbed a pen hole in the intake AFTER the maf. went and got some jb steel putty shit, kneaded it up and put covered the hole with it. went off and detailed my mechanics car *(he hooks me up on deals all the time so figured id do that for free for him) came back about an hour and half later, and reinstllated the intake in car, took some rubber and put it between intake and supercharger. issue is now gone. took it out racing Friday and Saturday. and no issue to be reported since those steps were done.
  18. Remove Advertisements
