front wheel hud replacement, step by step
Results 1 to 3 of 3
Cadillac STS-V Series Forum Discussion, front wheel hud replacement, step by step in Cadillac V-Series Forums; hey hey, had to replace another wheel hub/bearing. figured I would through up a quick step by step so if ...
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    hey hey, had to replace another wheel hub/bearing. figured I would through up a quick step by step so if anyone else needs it done you can see how easy it is.
    1, jack up car
    2, remove tire
    3, locate the two bolt that hold the caliber onto the knuckle (18mm)
    4, once bolts are completely removed, remove rotor and place on the lower control arm
    5, remove the torques screw on the front of the rotor (t30)
    6, remove rotor (if slightly rusted in place, lightly tap with a hammer to knock the corrison off)
    7, locate the three bolts on the back of the wheel hub holding it to the knuckle (13mm)
    8, disconnect the hub from the wire harness
    9, remove the three bolts and remove the wheel hub
    10, reverse the steps and your finished.
    pictures to follow.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: front wheel hud replacement, step by step
    Nice. Ill be referring to this when I inevitably have to replace mine. Thanks.
    Dec 2011
    Missouri
    31
    894
