changing front break pads...
Results 1 to 15 of 15
Cadillac STS-V Series Forum Discussion, changing front break pads... in Cadillac V-Series Forums; Does anyone have any links or information on changing the break pads on a 2007 sts v. I need to ...
    kjburto is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Sedan
    Mar 2013
    Saint Paul, MN
    37
    35
    Does anyone have any links or information on changing the break pads on a 2007 sts v. I need to replace that he front pads with these hawks I just purchased. Trying to decide if I should do them myself or have the dealer install them when they replace my radiator and head gaskets on tuesday. I tried using the search and couldn't find any info. Thanks
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,600
    Re: changing front break pads...
    Very easy they are quick change pads. Take of the wheel then take a punch and a hammer. And tap out the two pins going trough the caliper and pull out the pads and put in the new ones and tap the pins Back trough and that's it. 1hr tops I can do it in 15mins for all 4. If the car is allready jacked up.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Yes, it is easy.
    Are you really having the head gaskets replaced or is it the valve cover gaskets?
    Mar 2013
    Saint Paul, MN
    37
    35
    Quote Originally Posted by TimmyC View Post
    Yes, it is easy.
    My bad I think your right it was the valve cover gaskets, luckily its all covered under the extended warrenty I purchased.
    After replacing the pads is there anything else that needs to be done?
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    make damn sure the warrantee covers it!!! I had an extended on my car and I had to pay for them to tear it down before they would say if it was honored or not. could be a nightmare quickly.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    How do valve cover gaskets go?
    Mar 2013
    Saint Paul, MN
    37
    35
    Quote Originally Posted by boomys10 View Post
    They already told me it was covered just have 100 deductible
    Where is the best place to lift this car with a floor jack? The manual says the 2 slots behind wheel well. Can you place it anywhere else? Thanks for the help
    Feb 2009
    37
    1,897
    Put the jack under the front engine cradle or rear suspension cradle.
    Mar 2013
    Saint Paul, MN
    37
    35
    Is there something I need to do that im missing. I cannot get the old pads out on the first wheel. I got both pins out okay just cant pull the pads out. Any ideas can I use w wd-40 or something?
    Feb 2009
    37
    1,897
    Quote Originally Posted by kjburto View Post
    There is probably a lip on the edge of the rotor from wear. Might have to pry the pads past that.
    Mar 2013
    Saint Paul, MN
    37
    35
    Okay got the pads out now how do I get the new ones in, they are 2 times as thick?
    Feb 2009
    37
    1,897
    You have to press the pistons into the caliper with something.
    Mar 2013
    Saint Paul, MN
    37
    35
    Thanks for all the help by the way
    Got em thanks
  16. #14
    Dec 2011
    Missouri
    31
    894
    the gaskets just go bad. I blew all of them out on mine. EXPENSIVE to fix.
  17. #15
    Mar 2013
    Saint Paul, MN
    37
    35
    Yeah I figured everything would be expensive so thats why I got the 2 yr extended warranty.
    Thanks everyone for the help. Is there anything I need to do to break these new pads in?
  18. Remove Advertisements
