Hello all! Just joined, recommended from LS1tech.com! Couple of questions
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree1Likes
Cadillac STS-V Series Forum Discussion, Hello all! Just joined, recommended from LS1tech.com! Couple of questions in Cadillac V-Series Forums; Hello, just bought a 2008 STS-V, 38k miles got a great deal! installed the lockpick harness, works great! anyway, I ...
    fozjared is offline Cadillac Owners Member
    Automobile(s): STS-V
    Jun 2013
    33
    11
    Hello, just bought a 2008 STS-V, 38k miles got a great deal! installed the lockpick harness, works great! anyway, I have a few questions:
    how to stop door and seat belt dinger!?
    I have a check engine light, will the info center display a code for me?
    my windshield wiper spray tank has a leak, is this common?
    thanks so much everyone!
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Hello all! Just joined, recommended from LS1tech.com! Couple of questions
    I can answer your second question.. No the DIC doesn't do codes anymore.
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,602
    Fasten Your seat belt and close your door. And no a leaking tank is not common.
    is3_ftw and is3_ftw like this.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Is that what you meant by the belt thing?? No I don't have that issue. I don't buckle my seatbelt until I pull out of the garage and drive I couple hundred feet. Never had that issue.
    Drive a couple hundred feet.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,012
    My washer fluid leaks slowly until about 2/3 full, then stops. Tried to get the dealer to figure it out, now I just live with it.
    My seat belt dinger sounds for the passenger while just sitting and for the driver if I start to drive (and don't have the belt fastened).
    Jun 2013
    33
    11
    my washer fluid leaks out completely dry, thinking maybe the hose connection came loose on the bottom or broke off.. I guess I will have to go get autozone to pull the code for me.. and the door and seat belt dinger comes thru in the drivers dash speaker, just thought there might be a way to turn it off!? Can't stand a door dinger! when i am cleaning the interior i like to listen to the radio without dinging!
    Feb 2013
    Whitestone, NY
    28
    3,211
    Ohhhh!! Yeah when I'm doing the leather in the car and I'm in the driver's seat I have to sit through the constant chiming. I like to run the music while I'm working on the interior. If acc is off and the door is open, no music. As for the seatbelts, weird how the car will do the 5 chimes even before the car is put in gear when seatbelts are off. Speaking of which, I recently read in one of the automotive press magazines about some car, can't remember, maybe viper? That had a track version where everything was stripped from it except bare necessities in order to save weight. And it mentioned that the normal sound system was replaced with a single speaker because regulations required at least one speaker so seatbelt warning chimes could be played. So that being said, I doubt the warning chimes are avoidable.
    Unplug the speaker where the chime comes from?
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Doesn't the chime stop when you put the car to ON instead of ACC? Last time I was cleaning the interior, I'm almost certain that worked for me. I think the ebrake will bypass the headlights like on my grand prix too. Correct me if I'm wrong.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well you got off, acc, and the car running (on). If the car is either on or off and the door is open no chime. But with off, no music and with on, you could die if you're in the garage. Am I wrong? There's no other "ignition position" right? I know on cars with a real key there's on without starting. Then you start it and it defaults back to accessories I believe.
    Jun 2009
    2,012
    We have that......hold down to ACC for a few seconds and it goes to On, with no engine running.
    Problem is it turns on everything and will run the battery down pretty fast.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by fozjared View Post
    Hi fozjared,
    Welcome to the forum and congrats on your 2008 STS-V! Seems like you got a great deal and I hope you are enjoying it so far As you can already tell, members are highly active on these sites, and I can see some have answered your questions for you. I am here to help assist you with any questions or concerns. So don't hesitate to reach out to us!
    Sincerely,
    Laura M.
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Feb 2007
    Naperville, IL
    393
    For those with the leaky/leaking/empty washer tanks: They do crack. Mine was cracked near the bottom and had to be replaced. Was still under warranty at the time, so no idea of cost.
    Dealer said the plastic will dry out and crack if the tank stays near empty for some time (not using your wipers enough!).
    Bob
    Mar 2010
    Detroit, USA
    12,710
    Quote Originally Posted by bobs-sts-v View Post
    Bob
    Hello Bob,
    Thanks for sharing this information with everyone. I am sure they appreciate it. Please contact us if you have any questions or concerns that arise!
    Sincerely,
    Laura M.
  16. #14
    Jun 2013
    33
    11
    Thanks Laura, and thanks for all the info people!! This feels a lot like LS1tech.com, great community!! Yeah the only option i can see is disconnecting the one speaker, however, I lose the speaker for all music too!!
  17. #15
    Jun 2013
    33
    11
    one other quick question, to remove the outrageous hunk of plastic over the engine/ s/c, do you have to remove the bar between the strut tower tops? should the nuts be torqued when reinstalling the bar? I sold all my mechanic's tools when I decided to become a pilot..
  18. Remove Advertisements
