Options for Brakes STS-V
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac STS-V Series Forum Discussion, Options for Brakes STS-V in Cadillac V-Series Forums; Would bigger rotors than stock fit on either the back or front with the stock rims? I feel like you ...
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Would bigger rotors than stock fit on either the back or front with the stock rims? I feel like you could at least go bigger in the back. Also, does anyone know about carbon ceramic rotors? Are they available in our size, and who makes them. I also hear they're extremely expensive. Do they improve stopping power much? Some of the newer high performance vehicles are coming with them as options. Are there certain types of pads that are recommended with carbon cermaic rotors?
    http://image.automobilemag.com/f/mul...mic_brakes.jpg
    They're pretty nice too, the carbon ceramic brakes that is. Also how's the durability on these bad boys?
    http://www.automobilemag.com/feature...s/details.html
    Looks like they're more durable, 100,000 miles of regular driving. Obviously lighter, better stopping power, less fade. The only shortfall is going to be cost. I wonder how much though.
    PNBLWZD is offline Cadillac Owners Fanatic
    Jun 2010
    Los Angeles, CA
    46
    303
    Re: Options for Brakes STS-V
    Generally speaking, putting a larger rotor on any vehicle will require new caliper mounting brackets to make it fit. If anything, I think you would want a larger rotor in the front since that is where most of the stopping happens. Are the 14" Brembos not doing it for you? They are the same brakes used on the V2 IIRC. Many here have used the Stop-tech (or other brands) drilled and slotted rotors in stock size with good results and better looks.
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    1. Why would you need/want biger brakes on this car?
    2. Carbon ceramic brakes are only better under high heat. Ie road racing.
    3. You are looking at over $5,000 to try to do this. No one makes bigger steel brakes with 6 lugs so even steal would be very big $$$$. And carbon brakes would be stupid money.
    4. The car is 4500lbs so loosing 20-40 lbs in brakes is not really going to help any at all.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Just askin jeez. When you say they use the drilled and slotted with good results are we talking better than stock? Any issues with cracking especially with the drilled? How about pads? Is the general consensus that stock is the way to go
    Also, losing 20-40 lbs in brakes may not be a big deal but we're talking unsprung weight and lowering the rolling inertia so in that area, it will make a difference. To answer your first question as to why one would need/want bigger brakes, better stopping power would be the answer.
    The brakes are fine, but I just wanted to see what it would take to improve them, and how attainable that would be.
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Feb 2007
    Naperville, IL
    393
    Then start with the obvious - get a good set of Hawk Performance pads. Many to choose from. Gets rid of the brake dust as well.
    I use the Hawk HPS pads since I don't generate the high heat, especially here in Chicago's winters, but if you are in the south, you might try the ceramics. Suck in the cold, but decent in warmer climates (so I am told).
    I have had slotted and slotted + dimpled (not drilled all the way through) rotors on my V since '07, and never had any issues. Don't buy the drilled rotors - waste of $ IMHO.
    Just my 2 cents.
    Bob
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks bob. I know hawk is the way to go in general. That's my go to brand. My question is did you notice a difference in stopping power with any of your modifications? The stock brakes are pretty top notch. I wouldn't want to trade down. If you're not sure whether or not they made a difference I got it. Very understandable. Thanks again.
    Jailtime is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V, 95 Sierra Z71
    Jun 2009
    Velva, ND
    30
    349
    I have EBC Red Stuff pads and Black Dash rotors on my V. The combo is low dust, has good cold performance around town, and work great on the track. The slotted rotors are a nice apperance upgrade too. You can catch some pretty sweet deals on EBC parts at Place for Brakes.
    I hated the stock brakes, couldn't drive 50 miles without getting the wheels caked in brake dust.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks the brake dust kills me.
    bobs-sts-v's Avatar
    Feb 2007
    Naperville, IL
    393
    Stopping power with the HPS was excellent. HPC sucked, but that was due to cold temps in winter here in Chicago.
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well I'm glad you say that because ill be back to living in NYC in a year.
    Feb 2013
    Whitestone, NY
    28
    3,211
    by the way just happened to notice carbon ceramics on the SAE 100.
    http://www.conceptcarz.com/view/phot...100_photo.aspx
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    They appear to be V2 calipers as well.
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    Agreed. Those headlights are pretty sweet as well.
  16. #14
    youknooow is offline Cadillac Owners Enthusiast
    Automobile(s): STS-V 1 OF 3 BLK ICE & TANGO RED
    Dec 2010
    616
    Those head lights are on late model platinum escalades.
  17. #15
    CShiv's Avatar
    CShiv is offline Cadillac Owners Member
    Automobile(s): 95 STS (long gone) 07 STS-V(gone) 11 CTS-V
    Feb 2011
    Waldorf, Maryland, United Stat
    36
    68
    Man I gotta have those lights!
  18. Remove Advertisements
