'Shift to Park' Part Deux
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Like Tree3Likes
Cadillac STS-V Series Forum Discussion, 'Shift to Park' Part Deux in Cadillac V-Series Forums; A while ago, I encountered the lovely doors unlock, transmission locks into 3rd gear, DTC (0700) is set, and car ...
    beyerch is offline Cadillac Owners Member
    Automobile(s): NONE
    Sep 2009
    71
    A while ago, I encountered the lovely doors unlock, transmission locks into 3rd gear, DTC (0700) is set, and car displays 'Shift to Park' in DIC after parked and turned off..... The only way I could get around this was to unplug the battery for a while which was frustrating as it prevented me from doing any research with the Tech II.
    Today, while driving on the same road at almost the exact same spot, it happened again; however, this time the Tech II was sitting on the passenger seat. Here is some additional info about this problem.....
    - After going through DTC information for all of the active modules in the car, the only DTC set is P0700. I was hoping to find something buried in the IP or other Body module that might have provided more info, but unfortunately, no.
    - Clearing the DTC from the engine controller did in fact restore normal driving characterisics. The car would shift normally and I could control shifting in manual mode unlike the last time this happened.
    - Clearing the DTC from the ECM did *NOT* clear up the shift to park message.
    - Clearing DTC's from all controllers, I had a few random ones, did not clear up the shift to park message.
    - No matter how hard I tried, 'Shift to Park' and the annoying beeping persisted and I had to pull the battery again.....
    - I viewed Tech II data for the shift data items and nothing appeared out of the ordinary?? The parking lock / position indicator information all read properly according to the tool.
    - The Engine Light and Doors unlocked while I was cruising at a constant 25-28 MPH. I know the speed definitely as the street in question is a heavily policed area and they are very firm about enforcing the 25 mph limit.
    - Over the past couple week or so my car has been throwing up the 'Service Stability System' and a very rare 'Shift to Park' message. Shift to park has happened maybe 3 times in the last month. Over the past week, the 'Service Stability System' went from almost never appearing to happening 5 or 6 times while driving the car. If I do the Tech II test of the Steering Wheel Angle sensor it mostly passes; however, it sometimes fails. I've been waiting for warm weather to replace that sensor.
    I wonder if there is a shared circuit between these two systems?
    The weather has been rather wet the last couple weeks which is when the messages really started popping up.
    With all of that said, I strongly believe there is some sort of internal counter or monitor that is stored in one of the module's memory that has no way of being cleared other than disconnecting the battery. The next time this happens, I'll test this theory by pulling fuses to the modules individually instead of pulling the battery to see if I can narrow it down. I assume this is coming from the BCM, though.... After I reconnect the battery tonight, I"m also going to monitor the other errors in regards to the 'Service Stability System' to see if that starts behaving again.....
    Replacing the micro-switch may 'solve' this problem as well; however, at this point I want to understand why the nag message appears and never goes away until the battery is disconnected. If the switch was failed, pulling the battery shouldn't fix things... If the switch is intermittent, pulling the battery wouldn't fix things either unless the system is just keeping a running tally, etc....
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Re: 'Shift to Park' Part Deux
    Interesting. Keep the thread updated please. I recently had an issue where mine would not go out of park.
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    please do keep this running. im curious as to the outcome for!!
    hiltonny is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2008
    170
    I bought a 2008 last month that beeped every time the car was shut off with a message that it was not in Park. The dealer changed the shifter and the problem went away. There was a thread where the switch inside the shifter was replaced to correct the problem cheaper than replacing the shifter,http://www.partsgeek.com/mmparts/neu...illac/sts.html.
    faris789 is offline Cadillac Owners Member
    Automobile(s): STS v
    Feb 2010
    I had a very similar problem. Thankfully, the car was under extended warrant and I asked the dealer to take the car until the problem was fixed. Initially it felt like I had some gremlins in the car messing with me. Doors would lock and unlock on their own, car would go into limp mode, I could not get it to acknowledge it was in park when it was, I could not shut off the accessory and the battery drained. What it turned out to be was a sensor switch within the shifter not working properly. I know this sounds like it wouldn't solve the issue of door locks etc., but trust me it did. This problem started with one or two issues a few years ago and then one day, all hell broke lose.
    The part on my STS -V was the Transmission Internal Mode switch - FP part number 24242938
    Two years later, all is good and no similar issues have come up.
    Cheers. BF
    FourFather is offline Cadillac Owners Member
    Automobile(s): STS-V
    Nov 2012
    Wichita Falls, Texas
    59
    I love my STS-V, but I do have the "Shift to Park- Accessory Mode on" problem that started randomly and infrequently, but now is frequent.
    I appreciate the posts about this, and especially the part number listed above--STS -V was the Transmission Internal Mode switch - FP part number 24242938--and am wondering if there might be a "How To Replace the Switch" guide somewhere, to help me do it myself?
    Thanks in advance.
    Eddie FourFather Hill
    sts454049 likes this.
    Nimoch's Avatar
    Nimoch is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V, 2006 DTS Lux II
    Mar 2013
    Texas
    164
    I'm getting this issue almost every time I park now. I suppose I can buy the part and have a shop install it...
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    Sep 2011
    San Antonio Texas
    38
    148
    Took my car to dealer for the same issue I ask if they could adjust the linkage. They did but same thing kept coming up so they replace the shifter. My total was $ 701.00 part n labor. Car is better now, when I get out I think it gonna say shift to park old habits.
    Nimoch's Avatar
    Mar 2013
    Texas
    164
    I went to a buddy who adjusted the linkage; he had to do it twice as the first time didn't work. Crossing my fingers that I don't have to replace the shifter.
    Feb 2010
    Wow, 2.5 years after replacing the Transmission Internal Switch, the exact same issue has reared its ugly head. Shift into park for the last several weeks, now, dead battery overnight. I no longer have extended warranty and am going to plead my case to Cadillac, which I believe we all should be doing now... I live in a hilly area and downshift to reduce the stress on the brakes. I guess I wont be do that any more, the brembos, rotors and battery are much easier to replace than the switch. I think this is a re-occurring failed part issue and should be covered under recall. It's a switch for crying out loud and not a part which should wear out due to normal operation of this vehicle.
    Virgnslayer is offline Cadillac Owners Member
    Automobile(s): STS 2008 AWD V6
    Dec 2012
    5
    Did anyone fix this yet, my 2008 sts is pissing me off =(
    Nimoch's Avatar
    Mar 2013
    Texas
    164
    After 2 linkage adjustments I occasionally still get the error. A little wiggle of the shift knob will take it out of ACC mode.
    jasonp12's Avatar
    jasonp12 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS-V
    Jan 2014
    Northern California
    23
    244
    Mine does it for like 2 weeks. Then it stops for a few weeks. Then it comes back. I give up on it. Usually just a littlw wiggle fixes it.
  16. #14
    Carlosg's Avatar
    Sep 2011
    San Antonio Texas
    38
    148
    Yeah I had that same problem for a long time. I took to dealer to c if they could adjust they try but the same thing kept coming up. I had gave up already n I could have install it but I let them do it part was 300, n labor was another 300.
  17. #15
    jasonp12's Avatar
    Jan 2014
    Northern California
    23
    244
    Quote Originally Posted by Carlosg View Post
    Yeah no thank you. I can live with it before I pay that much.
  18. Remove Advertisements
