Hi beams want to flash on their own
Results 1 to 15 of 15
Cadillac STS-V Series Forum Discussion, Hi beams want to flash on their own in Cadillac V-Series Forums; Anyone else get this? Hi beams just randomly flash. Only stay on for a second, then switch back to low. ...
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Feb 2007
    Naperville, IL
    393
    Anyone else get this? Hi beams just randomly flash. Only stay on for a second, then switch back to low. Started when it was daylight and I had the wipers on, but doing it at random intervals with wipers on or off at night. Annoying, not only to me but the car ahead of me I am sure. Only other thing is I hit 80K and the DIC started the "service vehicle soon" message. Is this GM's way of getting me into the dealer? If I lived in Texas, it would get me killed! (and yes, I lived in TX for six years - Houston - so I can say that! )
    Bob
    1madstsv's Avatar
    1madstsv is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    Re: Hi beams want to flash on their own
    Check to make shore the auto on the rearview mirror is not on and just acting up. If it is off you need to go to the dealer and find out if that is why it's telling you service soon.
    indabackofdalac is offline Cadillac Owners Member
    Automobile(s): 2008 STS-V (present), 2004 DHS, 2000 & 1981 Eldorado (past)
    Apr 2013
    Manchester, NH
    11
    Just curious, how would the auto on the rear view affect it? I thought that was just for dimming the rear view?
    Regardless, I've had the same thing happen 4 or 5 times on my new (to me) 2008 STS-V... I've only noticed because of the indicator on the HUD/dash... when it has happened (within a couple minutes of starting the car), I've manually flashed them and it went away, but I am very interested to hear if there's a possible fix...
    Fierofiend is offline Cadillac Owners Fanatic
    Feb 2012
    Charlotte, NC
    338
    The "on/off" switch for automatic hi-beams is on the rearview mirror. Thats what he was referring to.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    Quote Originally Posted by Fierofiend View Post
    Yes that's what I ment to say. I for get not every one knows what all the buttons do lol.[COLOR="Silver"]
    bobs-sts-v's Avatar
    Feb 2007
    Naperville, IL
    393
    Not sure if related, but now the check engine light is on. So I have codes (didn't have any before). Anyone know what these are: P0700 and U0075.
    Kid mechanic of mine says the P0700 is for the trans, but the U0075 is a reserved code, meaning it shouldn't be used or is set by the dealer.
    Can't take it in til Monday, but would like any info I could before going in. They will also hear about the lights flashing on their own as well.
    An update to the lights - does it whether the rear view button is on or off. ONLY does it if the "service engine soon" message had been displayed, then does it quite frequently. Obviously something electronic.
    Let you know what they find on Monday.
    Bob
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Beyerch is getting the P0700 code but his is related to the "Shift to Park" that some of us have seen. It is sad that our cars are not aging well. We are seeing more and more electronic related issues. Good Luck with the Dealer visit and please let is know what happened.
    bobs-sts-v's Avatar
    Feb 2007
    Naperville, IL
    393
    So the cause of the P0700 and U0075 (which is a communication bus error) was that the battery was crapping out. Had the volts (14.2) but not the amps.
    Changed the battery and the those codes have not resurfaced. They assumed this was why the lights were flashing also. Until they went to wash the car.
    As soon as the water hit the car, the wipers went on and the high beams started going off on their own. So the tech spent the last 3 hours going through diagnostics and determined it is a bad wire in the harness. First the repair has to be approved by GMPP (extended warranty) and then they will attempt to replace the wiring harness. He showed me the schematic (yes, I know how to read them) and the high beams are on a circuit that is set to a specific voltage. When the voltage drops, the high beams come on. Since the wire is bad/going bad, it is only intermittent, but will eventually be a constant issue. Plugs seem to be OK (tech checked all connectors). So I wait now for GMPP to approve the repair, which the dealer says could cost up to $1200 (mostly labor charges). So no car back yet, but at least they have a working theory.
    Bob
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Jeez 1200. My bumper to bumper expired in February. Is it too late to get the GMPP warranty?
    STS LC3's Avatar
    STS LC3 is offline Cadillac Owners Member
    Automobile(s): 2008 STS V Raven Black-Ebony/Tango Red
    Apr 2012
    Cape Coral, Fl
    84
    Check with Black Cadillac. They sell a lot of GMPP Major Guard plans. Good pricing too. Hope it works for out for you.
    http://www.jamesblackcadillac.com/gmpp.htm
    Feb 2013
    Whitestone, NY
    28
    3,211
    Thanks a lot. I'll give them a call tomorrow.
    Feb 2013
    Whitestone, NY
    28
    3,211
    no go. they said since my warranty is already expired i'm out of luck. I was aware that's how it goes but was hoping to get lucky. Thanks anyway.
    bobs-sts-v's Avatar
    Feb 2007
    Naperville, IL
    393
    Got the car back yesterday. It even decided to rain here in Chicago, so I got to test out the repair. Everything working fine.
    Adjuster drove all the way out, saw it was a V, and immediately authorized the repairs. Never even touched the car. Only cost to me was my deductible.
    I can't even tell what they touched. The car was put back together without any noticeable difference - not even a fingerprint. Harness looks brand new, but that's it.
    Love my V-tech here at Naperville Cadillac.
    Bob
  16. #14
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    There is something about V-Techs!! I am happy with both of the V-Techs that have touched my car. I had on in KC at Superior and Mark out here in AZ at Kachina.
  17. #15
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by bobs-sts-v View Post
    Bob
    Hello Bob,
    I am glad to hear your vehicle was fixed and everything seems to be working fine. Enjoy driving your STS-V around!
    Sincerely,
    Laura M.
  18. Remove Advertisements
