Vacuum Switches
Results 1 to 7 of 7
Cadillac STS-V Series Forum Discussion, Vacuum Switches in Cadillac V-Series Forums; Hey all: Standing at the front of the car looking down at the supercharger, to the left there are 3 ...
    chwilliams3 is offline Cadillac Owners Member
    Automobile(s): 2006 sts v
    Mar 2013
    66
    Vacuum Switches
    Hey all:
    Standing at the front of the car looking down at the supercharger, to the left there are 3 electrical switches clipped onto the top of the engine.
    I had a lot of work done so it is possible that a mechanic missed this, but all 3 switches have vacuum ports. Only 2 have vaccum lines connected. The switch in the middle had nothing , not even a vacuum cap. I put on a vacuum cap, thinking that this could be a vacuum leak, and I did get better mileage.
    Does anybody know what these switches are for and if all of them should be connected to vacuum lines??
    Thanks for your responses all. L
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Re: Vacuum Switches
    Only 2 should have vacuum lines. The 3rd is atmosphere pressure.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Re: Vacuum Switches
    Quote Originally Posted by Fierofiend View Post
    Correct. Cap is not necessary.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    Re: Vacuum Switches
    Does it matter which two are connected?
    (I dont have a V just going for clarification.)
    Mar 2013
    66
    Re: Vacuum Switches
    How do you calibrate the sleeve at the MAF. I had some mechanics at the body shop install it and I don't think they knew about the sleeve. Thanx
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,663
    Re: Vacuum Switches
    Quote Originally Posted by chwilliams3 View Post
    That depends on what you are talking about. If you are talking about a stock intake there is no true calibrating needed. Now if you are talking about a Spectre Intake the sleeve that is included takes care of that and it only goes in one way. The slit goes around the MAF sensor. Now you can move the orentation of the MAF sensor, and that is called "Clocking" the MAF sensor and it needs to be done on a dyno to check the power output but is only good for a few ponies. Finally if you are talking about one of Tim's intakes he will have to come in and speak to that. I do know his needs a tune to correct the MAF table. But I don't know if he does any clocking on the MAF.
    CMNTMXR57's Avatar
    CMNTMXR57 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V, 2004 Pontiac GTO, 1999 Chevrolet Suburban LT 4x4
    Feb 2009
    Chicago
    45
    1,328
    Re: Vacuum Switches
    That middle one (#819) that is purposely meant to be open, as it is an outlet sensor of some sort. You have an inlet, and barometric pressure sensor also. Here is an exploded parts view I got from the parts department when I too inquired. You can also see the tubes that attach to #818 and #820 (parts #816 & #817). Personally, I bet he wrote them down wrong because it would make sense that the inlet and outlet sensors are hooked up via those tubes and the barometric pressure one would be "open-air".
  10. Remove Advertisements
