STS-V Ride
Results 1 to 7 of 7
Cadillac STS-V Series Forum Discussion, STS-V Ride in Cadillac V-Series Forums; I've been kicking around the idea of getting a STS-V, I do miss my old STS V8 with MRC. Question ...
    Caroutisine is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS V8
    Dec 2006
    522
    STS-V Ride
    I've been kicking around the idea of getting a STS-V, I do miss my old STS V8 with MRC. Question is does the STS-V ride a lot stiffer than the regular STS with MRC? Does it have runflat tires from the factory? I hate runflats and can't remember if these cars had them or not. Prices on the V are getting so good it has me thinking abour getting one.
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,979
    Run Flats from the factory, but most people get rid of them. I can tell you that my V rides better than my regular STS with AWD, but I don't have MRC.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Re: STS-V Ride
    I've had all suspension levels the STS and the V is the stiffest. It's not a reason not too buy the car though. You get used to it right away.
    Thunder Gray STS's Avatar
    Thunder Gray STS is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Premium
    Jun 2009
    Memphis TN
    50
    236
    It is substantially stiffer than any of the regular STS cars. It does come with run-flats, however, I took off the run-flat tires and put on regular tires and the ride improved substantially.
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    48
    600
    Re: STS-V Ride
    i think its a function of air pressure too.I fooled aroud with mine and run them 28 in frnt and 35 in back--still have runflats and have gotten 2 floats in 3 t=years
    YoungBlood_STSV is offline Cadillac Owners Fanatic
    Sep 2010
    277
    Re: STS-V Ride
    In terms of %, I believe the V's springs are 15-20% stiffer than the base sedan. It has thicker sway bars too, if I'm remembering correctly.
    As everyone has said, dumping the RFT's and playing with tire pressure helps the ride substantially. I actually run my tires a little high, 35/38...as the softer sidewall on regular tires seemed to cause premature wearing on the shoulders of the first set of tires I had when I inflated them to the specs listed on the door jam. I haven't had any tires issues at all in the past two years since changing to regular tires and upping the pressure by 4-6psi.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by YoungBlood_STSV
    33 mm on 1sg v8 and 24 mm rear on awd same as v. V front is 36 mm.
  10. Remove Advertisements
