cluster message: ENGINE HOT - AC OFF
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Cadillac STS-V Series Forum Discussion, cluster message: ENGINE HOT - AC OFF in Cadillac V-Series Forums; got a wierd message today. I was driving in the snow, 8 degree michigan weather. After 10 minutes of driving, ...
    bjherron123 is offline Cadillac Owners Member
    Automobile(s): 07 STS-V
    Nov 2012
    37
    43
    got a wierd message today. I was driving in the snow, 8 degree michigan weather. After 10 minutes of driving, and 4 minutes from home, the cluster said ENGINE HOT - AC off. It then disabled my AC. I tried to turn it on just to see, and it wouldn't come on. At the same time, my temp gauge needle stopped working and went to the cold side.
    I used the dash to determine that engine oil temp was 158 and not rising. Trans temp was 98, so I kept driving (did I mention it was snowing). Got home, and did notice the cooling fans running on full as I pulled in the garage.
    anyone have this happen? still covered under the CPO, but this may be hard for them to reproduce.
    Brian
    carter's_sts is online now Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,031
    From reading on here, that message can mean overheating (not in your case) or it means the coolant temperature did not get up to a certain value in a certain amount of time (stupid).
    Usually its the thermostat, but with your temp gage going to the bottom, it might be the coolant temp sending unit.
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,663
    Re: cluster message: ENGINE HOT - AC OFF
    Yes, a lot of us have had this happen. It's the Thermostat.
    Fierofiend is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS-V
    Feb 2012
    Charlotte, NC
    338
    Coolant temp gauge always goes to zero when this happens. Do a search, this has happened to almost all of us,lol. Its as he said, not getting up to temp,usually a thermostat. The computer really needs a software update to fix this issue, Cadillac should have realized this by now.
    Berger 93 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac STS-V
    Feb 2007
    Schaumburg, IL
    317
    Still contending with this . . weather went south and have not had a chance to get the car out . . . and now the battery died . . buh . .
    Jun 2009
    2,031
    Battery tender. I plug mine in usually for the whole week, since its mostly a weekend car.
    YoungBlood_STSV is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Sep 2010
    277
    In 8 degree weather I would let it slide this time. If it does it multiple times as the weather warms up you need a new t-stat. Simple Fix.
    brbevil is offline Cadillac Owners Member
    Automobile(s): STS-V
    Oct 2010
    49
    32
    Just happened to me last month. Easy fix. Be sure to take your existing thermostat to the parts store. Advance auto parts had two listed. Unfortunately the one I bought was too big. Second time worked perfectly. Took me about 4 hours. I am a complete novice and spent lots of time looking around checking other things out. Good luck. Oh FYI. Thermostat was 15$ if I remember correctly but had to get new gasket from dealer. It was 8 dollars.
    terrydactul is offline Cadillac Owners Member
    Automobile(s): Sts V
    Nov 2011
    40
    I had the same thing a few weeks, took it to the dealer under warranty..they replaced the Thermostat and problem solved.
    tino160 is offline Cadillac Owners Member
    Automobile(s): 06 sts v
    Mar 2010
    10
    Mine started this today. Showed the messaage and temp gauge stays on cold the whole time as soon as i start it up. I am guessing it's the temp sensor and not the thermostat since it does it as soon as it starts. Am I rite?
    PGA2B's Avatar
    Jun 2009
    USA
    2,663
    No. Thermostat.
    Mar 2010
    10
    Thanks, I will pick one up.
    rwwrrr is offline Cadillac Owners Member
    Automobile(s): STS-V 2008
    Apr 2010
    49
    36
    Mine has done this for a week now. Last time it just went away. Guess I am off to auto parts store.
  16. #14
    JeffB13 is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V
    Apr 2011
    Gig Harbor, WA
    24
    Yup, Thermostat. Happened to me last summer in the middle of a 2 hr trip.
  17. #15
    theotherguyssn's Avatar
    theotherguyssn is offline Cadillac Owners Fanatic
    Automobile(s): 06 sts-v
    Mar 2013
    columbia sc
    32
    261
    there is also a update for the engine control module for it setting a p0128 intermittantly. coolant not getting to operating temp, mine did it right after i bought it put the install in as well as a thermostat just to be safe
  18. Remove Advertisements
