Hi, there
look what I found today at Road&Track!!!
The new STS V Supercharged 440 hp - that`s it!
TitanCTS said:Btw, More titanium trim would be better along with some carbon fiber accents besides the ash burlwood!
What in the heck is your position at Cadillac? Are you in the RenCen or out with the engineers? I must say that you covered all, and I mean all, of the important technical data in terms that the average person can understand. I've never met an engineer that could do that!********* said:The R&T article is pretty good for some of the details of the car as well as the pictures and such. The GM Performance Division worked closely with Cadillac and R&T to come up with the "reveal" in the February R&T issue since the STS-V will officially be unveiled in person at the Detroit Auto Show in early January. This will be the magazine cover on the newstands during the Detroit show so it is particularily timely....
Since GM worked very closely with R&T the article has pretty good info and is fairly accurate.
Basically, I cannot imagine any descriminating motorist being unhappy with the STS-V. It is an excellent blend of track level performance and refined elegance in the same car. The STS is an excellent starting point and the HPVO group in the GM Performance Division was allowed free rein to incorporate the modifications necessary to make the car perform at that level, make it track capable off the show room floor and add the uplevel luxury befitting a car like that.
The "leather wrapped" interior has to be seen/touched/smelled to be fully appreciated. It basically blows away most anything else regardless of "value" or "price point"....
The entire suspension/brakes/driveline has been replaced with re-engineered parts to significantly increase the performance level of the car. This is not just a bolt on of other parts from other GM cars. These are new parts specifically designed for the STS-V. An example is the engine placement in the car. The engine is actually lowered almost 2 inches in the chassis compared to the production STS...a modification that would be unheard of years ago...yet one that was deemed necessary regardless of the expense for vehicle balance and packaging so it was incorporated into the STS-V.
The goal of the car was unquestionable performance on the track where it will be judged next to the competitors. One example of the dedication to this was the use of the more conventional mono-tube shock absorbers rather than the magna-ride system. Given a specific endeavor, such as track work, the monotube shocks can be developed to a higher absolute level than the magnaride system at the moment...so the decision was made to go with the monotube design. The magnaride allows a far greater range of chassis control in terms of smooth and soft ride quality at the one end of the extreme but, within the narrow performance band, the monotubes were still judged to be better after much evaluation and tuning so they were used. Everything in the car was subjected to this type of scrutiny to make sure it was the best available for the purpose of the car.
The outside body panels include a new, composite hood with a slight "power bulge" to clear the supercharger, fascias, valence panels, etc. including the wire mesh grill. ALL the body panel changes were developed in the wind tunnel to improve vehicle aero balance, cooling, duct cold air to the front brakes, duct air to the differential cooler, etc... All of it is funtional and none of it is "rice"...
The six speed auto trans is a new piece that will set the standard I feel for normal automatic trans operation and track oriented "tap shift" or manual control. The trans has the heavily developed Performance Algorithm Shifting logic built into it and it really works on an autocross track or the racetrack if you decide to leave the tap shift alone. With 6 forward speeds the trans can match the perfect engine speed at any vehicle speed which almost completely negates any advantage a continuously variable trans would have while allowing the launch capability of a torque converter combined with the traction control system.
The engine is a supercharged, 4.4 liter version of the VVT rear wheel drive Northstar. Just about every part in the engine is new, however. The basic architecture of the engine is based on the rear wheel drive Northstar but virtually every part and fastener is specific to the supercharged engine. The block is a precision sand cast part with a closed deck design which is the first time a Northstar engine did not have a die cast block with an open deck. Lower crank case, heads, etc... are all unique castings for the supercharged version.
The supercharger/induction system on the engine incorporates several patented features that were developed by Cadillac for the engine. The air intake to the supercharger is at the rear of the engine and underneath the supercharger and the supercharger blows pressurized air upwards thru the intercooler tubes on the top. The air then makes a single, smooth 180 degree turn down into the individual induction tubes along the outside of the supercharger housing.
The performance of the engine is very exciting. At 440 HP @ 6400 the engine is making 1 HP per liter of displacement....a specific output that is better than most any engine on the market...even some of the exotics...and much better than the E55 which has a screw compressor, even. Better yet, the 1 HP per liter is obtained at 6400 RPM....not the 8500 RPM required by some of the competitors. Reading between the lines this means that the engine has huge torque and a very very wide torque curve that is what will really move the STS-V. About 90% of the engines peak torque is available from 2800 RPM thru 6500 RPM meaning that it pulls like a locomotive no matter what gear you are in. The engine is rated at 430 lb.ft. of torque at 3600 RPM.
The engine will be built at the dedicated Performance Build Center in Wixom, Michigan by trained engine builders. Each engine will be built by a single assemblers to insure ownership and quality of the powerplants. The PBC is representative of the commitment of GM to competing with the best in the world in specialty cars and engines. There was a need for a facility to build very low volume engines that require special assembly techniques and care so the PBC came into being. It combines all the error proofing and fastening techniques of the normal assembly process with dedicated assemblers in a low volume atmosphere. Here, each engine can be assembled by one person and appropriate care and time devoted to each engine to ensure that it is done correctly without the demands of high volume production and the necessary automation restricting what can be done in the engine design and manufacturing techniques.
I have seen quite a few drivers that are used to some very fast and high output engines drive the prototype STS-V cars and I have yet to hear one that was dissatisfied with the performance.
Both the intake and exhaust sytems are specific for the STS-V and heavily developed for low restriction and high flow.... No "cold air intake" from the aftermarket required....LOL. The engine group set some extremely aggressive targets for inlet restriction and exhaust backpressure to obtain the 1 HP per liter goal and the targets ended up being exceeded by the induction and exhaust groups. Amazing little inlet restriction, excellent induction noise control and low backpressure still meeting the passby noise targets.
Keep in mind that a supercharged engine has to overcome the parasitic load of the supercharger.....so...in this case the engine is actually making over 500 HP when you consider what it takes to drive the supercharger at peak power. That means that the fuel system, cooling, etc... all are actually handling 500 HP....
The various STS-V mule vehicles and prototypes have lived on the Milford Road Course , the Nurburgring and several other race tracks around the country since the program started. I cannot imagine a vehicle (aside from the Corvette) that would have accrued as much track time during development as the STS-V. Actually, within the past 2 years any time there was a Corvette track test there were STS-V cars there also so it probably has more track time per vehicle than the Corvette mules given the number of laps turned.
BTW....the cars are being driven by very competent test drivers. One of the aspects of HPVO is to train and certify drivers against some of the best in the world so that vehicle performance is accurately rated. To say that some of the drivers of the STS-V program are "good" is an understatement. John Heinricy, who is very well known as a racing driver outside of GM, is the head of HPVO so he serves as the gold standard for driver performance. This really raises the bar in terms of vehicle performance and capability as the driver level is good enough to as to tax the car to the very limit.
The racetrack is certainly not the final answer for any car but a lot can be learned about the durability and performance of things like the powertrain, cooling capacity, fuel system (fuel pickup during slosh), etc... so the advantage of being able to test the STS-V almost daily on the MRC was huge.
The vehicle is track capable off the showroom floor with adequate brake cooling to ensure fade free performance at the performance limit for a full tank of fuel on the track. There are dedicated coolers for the radiator, engine oil, trans, power steering, intercooler heat exchanger, air conditioning, final drive, etc... that all meet track performance requirements in hot weather.
One of the main goals with the car was to provide this level of absolute performance while maintaining complete "street-ability" and requiring no compromises on the driver in daily traffic. This is one place the 6 speed automatic trans shines. It performs like a racing transmission on the track yet allows for simple stop and go traffic on the commute. The engine power level and power band is important here, also, as a high revving, peaky engine can get pretty tiresome in traffic and has low real world "cut and thrust" performance without constantly shifting. The supercharged Northstar comes to life with just a slight nudge of the pedal. NVH tuning was especially critical for the real world phase of operation as induction roar, droning exhaust booms, etc...would really detract from a world class car and would not be acceptable. All these types of things make the STS-V a world class luxury performance sedan that requires no special compromises by the owner/driver. One nice feature is the acceleration performance of the package. The engine power band combined with the torque converter/auto trans and launch traction control put the sub-5 second 0-60 times in the hands of every driver every time... no special clutch slip or launch procedure required for best times. Just stab the accelerator...but be sure you are pointed in the correct direction first.
That's strange. Everyone seems to love that color combo in the 2005 Mustang, but put it in a muscular Luxury car and it's terrible.Playdrv4me said:That red interior is absolutely disgusting by the way. Reminds me of that burgundy interior color I saw on an LS430.
Brett,Brett said:red interior pics
Are you trying to tell us something?********* said:What XLR-V.....?????
Lest we not forget that the STS-V is powered by a massaged Northstar, the CTS-V is still the king when it comes to real American self-aspirated muscle.b4z said:It is a more successful rendition of the "V" theme than the CTS-V.
Playdrv4me said:Lest we not forget that the STS-V is powered by a massaged Northstar, the CTS-V is still the king when it comes to real American self-aspirated muscle.
the Sandman said:Are you trying to tell us something?
cardio-doc said:I've been holding my breath for 5 years now waiting for Cadillac to roll-out this "Pace Car" edition. Should I stop waiting?
~Doc
b4z said:bbobyinski,
The 2005 CTS-V was on delaer lots in July 2004.
Do you think we will see the STS-V production begin in June and be on the lots in July 2005, or will be October/November time frame?
Kind of like the way 2004 CTS-V was introduced.
Is the rear end whine problem been taking care of on the Sigma cars,
or is just something we have to live with?
My SRX whines as does my brand new GTO.
GM problem?
First that I have ever heard of the "beveled gear" explaination....LOL.Katshot said:Maybe it's not the same thing but years ago (about 1993) Cadillac started using rears that were only previously used in GM trucks, and IMMEDIATELY started getting complaints about gear noise (gear whine). The fix was to replace the gear sets with beveled gear sets. Seems that the ones originally used were NOT bevel cut because they were used in trucks and since the cabin noise level of a pick-up is a good deal higher than a Cadillac limo.....
Get the picture?
Maybe this is a similar issue?
Where is everyone seeing this 4300 number? Every time I see it I go into denial because it is so depressing. The E55 AMG doesn't even crack 4100 and I usual expect Benzes to be heavy. Less power, a LOT less torque, and significantly more weight. A lot less horsepower than an M5, a lot more torque, and significantly more weight. Whoopee doo. A let down considering it was hot on the trail of the CTS-V which blew everything away.b4z said:I just saw that the STS-V weighs 4300lbs!!
Dang. that thing got heavy, fast.
The CTS-V weighs 3850 and the STS_V is 450lbs more.
All that performance stuff really puts the lbs on.
