WOT problem
Results 1 to 12 of 12
Cadillac STS-V Series Forum Discussion, WOT problem in Cadillac V-Series Forums; I've had my STS-V since August 2012. I just began to get used to it and started seeing what it ...
    FamofV's Avatar
    FamofV is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V
    Aug 2012
    Antelope Valley
    14
    WOT problem
    I've had my STS-V since August 2012. I just began to get used to it and started seeing what it can do.
    I noticed that after WOT runs the engine , not the exhaust, smells like its on fire. What can this be? Anyone have a simliar issue?
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    Re: WOT problem
    how many miles on it?
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    Re: WOT problem
    It's more than likely you brakes from having to stand on them to slow down.
    http://www.youtube.com/watch?v=gfQ8h...e_gdata_player
    FamofV's Avatar
    Aug 2012
    Antelope Valley
    14
    Re: WOT problem
    Thanks for the replies.
    The car has 26K miles.
    I didn't consider it being the brakes given that their supposed to be good. I'll look into that.
    bjherron123 is offline Cadillac Owners Member
    Automobile(s): 07 STS-V
    Nov 2012
    36
    43
    Re: WOT problem
    I have the same problem, see my post here:
    http://www.cadillacforums.com/forums...-wot-runs.html
    it's not the brakes, as it happens even after on-ramp acceleration to the hiway. I'm convinced it's the cats. I took it to the dealer but they were basically unwilling to do anything, citing a TSB that says it can be caused by bad gas. But for me it happens all the time, and I fill up at several different gas stations.
    I have 36K miles on my 07.
    Brian
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: WOT problem
    FamofV, I do suggest bringing your concerns to your dealer's attention and having their technicians run the proper diagnostic checks on your STS-V. I'm happy to contact your dealer anytime you would like to involve them, and I'm also here to check for any possible recalls, etc. that may be open on your vehicle. If you would like me to look into the matter further, please send me an email at Katie_Lucille@gmexept.com that includes the last eight of your VIN.
    Best,
    Katie
    FamofV's Avatar
    Aug 2012
    Antelope Valley
    14
    Re: WOT problem
    I took the car in today to my local Cadillac dealer for service. I'll see what they tell me about the burning smell. The smell would appear during normal driving and WOT.
    Nov 2012
    36
    43
    Re: WOT problem
    let me know what the result is, and if they try to tell you to run different gas too!
    FamofV's Avatar
    Aug 2012
    Antelope Valley
    14
    Re: WOT problem
    So far the verdict is that the burning smell is a result of oil leaking form the heads onto the manifolds. Who would have thought that with such a low mileage car.
    PNBLWZD is offline Cadillac Owners Fanatic
    Jun 2010
    Los Angeles, CA
    46
    303
    Re: WOT problem
    Or maybe a leaky valve cover gasket onto the manifold?
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,956
    No smell for me, but I had to have an oil leak fixed at only 28k miles.
    Dec 2011
    Missouri
    31
    894
    Re: WOT problem
    i had mine fixed at 70k, but it was a total tear down of engine. i was informed from my mechanic that the pressure in the crank case can force a small amount of oil out of the rear main seal also. i would invest 30 in a vent to see if that helps before the next step.
  15. Remove Advertisements
