Electrical problems... yeah....
Results 1 to 7 of 7
Cadillac STS-V Series Forum Discussion, Electrical problems... yeah.... in Cadillac V-Series Forums; [ UPDATE : Reconnected battery after getting home from work and car is running OK for now. Ironically the only ...
    beyerch is offline Cadillac Owners Member
    Automobile(s): NONE
    Sep 2009
    71
    [UPDATE : Reconnected battery after getting home from work and car is running OK for now. Ironically the only time I didn't have my Tech II in the car was today......... Also found that the air filter was not connect to the intake and was sucking in open air, but that's a different post, lol. ugh......
    In regards to the issue at hand, since it is now working after the battery was disconnected, I see two possibilities here:
    a.) An intermittent switch issue triggers this event; however, something in the software gets confused and never recognizes that the switch is now functioning properly. Only when the battery is disconnect and the computers 'forget' does this then work again.
    b.) Something in the microswitch / shifter assembly physically is tweaked until power is dropped it doesn't reset. Easy enough to verify if I can get the car to do it again and have access to the center console. If this is the case, a simple momentary depression switch inline with the connector could be put in place as a 'reset' of sorts.
    I'm pretty sure this is going to turn out to be an electrical problem, but I'd love any input on this. I was driving around my 06 today (30-35 MPH) and all of a sudden the check engine light came on and the doors unlocked at the same time. A few seconds later, I noticed that the transmission would not shift out of the current gear (which was a problem as I was on a ramp to an expressway?!!?) and it ran all the way up to 5,000 RPM before I gave up and got off the next exit.
    I pulled into a parking lot and check the basic stuff on the DIC such as transmission fluid temp, etc. Temps all seemed normal, etc. Then I put the car in park and turned it off. The car was dinging non-stop and the message 'Put car in Park' continually flashed on the DIC. I have to note, this is a horrible design since it will just drain the battery.... I started the car back up and I limped it back home...
    I hooked up my trusty Tech II and pulled a plethora of codes. If there is a common link to any of these, I'd love to hear about it:
    ECM & TCM
    P0700 - TCM MIL --> [I assume this is why the trans locked in gear]
    P0106 - MAP Sensor Performance
    RCDLR
    B3121 Antenna 3 Performance Short to Open
    B1440 Power Mode Master Mismatch Signal Invalid
    U2162 Lost Comm w/ Integration Panel Integration Module
    HVAC
    U2103 - Fewer Controllers on Bus than Programmed
    IPC
    U2172 - Lost Comm w/ digital radio receiver
    Radio
    U2103 - Fewer Controllers on bus than programmed
    Nav
    Driver's Seat
    B1860 - Lumbar Signal Invalid
    B1850 - Lumbar Signal Invalid
    From my quick googling, it seems the RCDLR is somehow associated to the 'Put Gear in Park' business and since I'm seeing multiple DTCs from that device, that may explain that one. (though none of the DTCs seem to refer to the park mechanism??)
    The ECM code is a mystery as that code alone doesn't seem to indicate much of anything.
    The driver's seat codes, meh.....
    The other codes indicate some type of bus communication problems?
    Anyone ever see something like this? Any input appreciated!
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,661
    Re: Electrical problems... yeah....
    Sounds like the Neutral Safety Switch that GM calls a Transmission Position Switch/Sensor. Same thing happened to me but I was luck to only be backing out of my garage.
    http://www.cadillacforums.com/forums...k-morning.html
    Automobile(s): NONE
    Sep 2009
    71
    PGA2B,
    Yeah I saw some of that earlier this morning while googling, but that thread was much more insightful as it had a couple people who also experienced the locking in 3rd gear issue that I did as well and the P0700.
    Car is currently sitting in my garage with the battery unplugged so I guess we'll see if it's still doing it after I plug the battery back in. Guessing I'll order up the shifter now even if it is "working" just so I have it. (Guess I'll also keep the battery wrench in the car in case this happens while traveling......)
    P.S. I emailed/PM'd you on him a while back, did you get that?
    Thanks!
    torched10's Avatar
    torched10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 sts v, 2011EXT,65 GTO,08 vette,gt500
    Jan 2010
    atlanta
    48
    600
    i had the put in Park message a month ago and they had to replace the top end of the shfiftre unit,under warranty, or it would have been 700 bucks.But my car would drive it just wouldnt let me turn it off
    Automobile(s): NONE
    Sep 2009
    71
    I'm guessing they replaced item #34 on this diagram?
    http://www.trademotion.com/media/ima.../B/BC05400.gif
    PGA2B's Avatar
    Jun 2009
    USA
    2,661
    Quote Originally Posted by beyerch View Post
    Sorry, but no. Use the email function as I have not had PM's since I stopped being a vendor here.
    Automobile(s): NONE
    Sep 2009
    71
    Just in case anyone needs it part number is : 19179513
    A better parts diagram (view it at full size)
    http://www.tonkinonlineparts.com/sho...ssembly=847327
  10. Remove Advertisements
