Please read immediately if overboosted!!! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Cadillac STS-V Series Forum Discussion, Please read immediately if overboosted!!! in Cadillac V-Series Forums; Thank you for the info Boomy....
  1. #16
    parkeraire's Avatar
    parkeraire is offline Cadillac Owners Fanatic
    Automobile(s): 06' sts-v
    Mar 2011
    Lee Co. FL.
    47
    169
    Re: Please read immediately if overboosted!!!
  2. #17
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    804
    Quote Originally Posted by boomys10 View Post
    the zzp link is the exact thing needed. its not a big investment, but spend the 30 and get one. its alot better than 8k at a dealer if you dont have access to a dealer mechanic.
    I saw this note at the bottom of that filtered breather you mention, " *PCM programming required on cars with drive by wire throttle bodies. "
    Is that the case?
  3. #18
    silver sts-v is offline Cadillac Owners Member
    May 2012
    PA
    65
    Timmy,
    In the LS series it too will spit out oil if the fill cap is off. The K&N had a stepped down or smaller vent hole for this exact reason and I have never had a problem with oil outside the engine. Maybe a Caddy is different with the DOHC but we use this same system on Fords with the same set up.
    I still don't know what a ZZP is and info does not Google.
  5. #19
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
  6. #20
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Quote Originally Posted by silver sts-v View Post
    Timmy,
    Hmm, ok. I had a lot of oil dripping out of mine when I had the turbo setup on my car but I didn't have any baffling.
  7. #21
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    Sep 2011
    San Antonio Texas
    38
    148
    Where did the oil start to leak from?
  8. #22
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    Even with our 1000 rwhp plus builds, using the RX Monster can for FI (the only crankcase evacuation oil separating system on the market that provides proper evacuation at both boost and non boost operation aside from a belt driven vacuum pump system) takes care of all pressure issues and does not defeat the evacuation process so critical for street driven FI. Any time you do one of the "vented" systems you defeat all evacuation and the damaging combustion byproducts remain in and concentrate in the crankcase oil shortning engine life unless you change oil after every few runs.
  9. Remove Advertisements
