Exhaust Smell after WOT Runs
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac STS-V Series Forum Discussion, Exhaust Smell after WOT Runs in Cadillac V-Series Forums; Does anyone notice a bad smell from the exhaust for several minutes after a full throttle run up? I just ...
    bjherron123 is offline Cadillac Owners Member
    Automobile(s): 07 STS-V
    Nov 2012
    36
    43
    Does anyone notice a bad smell from the exhaust for several minutes after a full throttle run up? I just purchased my STS-V and on the drive home the smell was bugging me. I'm sure it has to do with fuel enrichment when you go to full throttle and the catalytic converters. But I've never had a car where the smell was that bad, and for that long. It seems to take 10-20 minutes to clear up.
    Has anyone else experienced this?
    Brian
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,978
    Sure that's not burning rubber? Ha ha......seriously, I haven't noticed that.
    b4z
    b4z is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Standard SrX grey/black 2006 GTO
    Mar 2003
    Chas. SC
    54
    1,795
    Re: Exhaust Smell after WOT Runs
    Brakes.
    1madstsv's Avatar
    1madstsv is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    You should not smell any thing in side the car from exhaust. If you are there is a big problem check for leaks. My cats were clogging up but I still had on smell and they are removed now and still no smell.
    silver sts-v is offline Cadillac Owners Member
    Automobile(s): 2007 STS-V
    May 2012
    PA
    65
    Mad,
    We have spoken before - how did you gut the cats? Seems that you must take the exhaust manifold off to do it or is that my imagination? Also, any engine 'booming/drone' from this modification? Old minds in Hanover want to know.
    'dog
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    No very easy to do undo the pipes where they connect to the cat and stick a big screwdriver up there and beet it out then start car and rev it up. Reconnect pipes and your Dunn
    May 2012
    PA
    65
    Quote Originally Posted by 1madstsv View Post
    And you have no droning? I am led to believe that this droning is prevalent if you gut these cats. Thank you.
    1madstsv's Avatar
    Aug 2010
    York pa
    32
    1,599
    I had drone from my mufflers Gutted cats and it actual went a way some. So at least it did not get worse. I'm off work to day if your a round I could run up and meet up with you. Ryan
    May 2012
    PA
    65
    Just got your reply - - today won't work but about anytime tomorrow if you want. 877-227-9090 and leave message if I am out.
    Nov 2012
    36
    43
    drove it some more. pretty sure it's a catalytic converter. The car is not showing an OBD2 code so hopefully it won't be a hassle to get the dealer to repair it under the CPO warranty or EPA 7year. It's only noticable when you drive it agressivly but hopefully they will understand
    also noticed the right LED brake light is out.
    Brian
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,661
    They will not SOP the manifold unless you are setting a CEL. Trust me I know........ I couldn't bring mine in until I had a steady light. Mine would come on for a few days and then reset. My apt at the dealer was yesterday and Thursday on the way home from work my light went off. I was like "F@#K" luckily it came back on just before I got home and stayed until my appointment. They ordered mine and will call when it comes in. I have forced the code off until I get the new manifold.
    007STS is offline Cadillac Owners Member
    Feb 2012
    31
    29
    If u are smelling exhaust inside your car when you roll the windows down and not so much when there up I may have an answer for u. It took me a year to figure out, I checked all the body plugs everything u could check, nothing, then on day my car was on the lift, upon inspection of the rear end I noticed something out place above the rear wheel well, I reached up and pulled a vent out that was obviously bad, I tried to clip it back in and was just too loose, we have one above each tire, my mechanic ordered replacements and ever since I have not smelled exaust while cruising or wot with windows down. I found this out of luck so I hope it helps, it annoyed the ish out of me forever !
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    I had a friend tell me that gutting the cats will cause back pressure problems is this true? I want to do this myself when I get an exhaust system
  16. #14
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,894
    Quote Originally Posted by cadi509 View Post
    No, that's nonsense.
  17. #15
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,524
    Honestly I've heard the same thing...
    Nice to know it's just someone blowing smoke.
  18. Remove Advertisements
