Anyone with a smaller pulley PLEASE enter
Results 1 to 15 of 15
Cadillac STS-V Series Forum Discussion, Anyone with a smaller pulley PLEASE enter in Cadillac V-Series Forums; Ok, so I could not figure out what was going on in my car since the pulley swap. In 3rd ...
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Ok, so I could not figure out what was going on in my car since the pulley swap. In 3rd gear I could only get to 106mph before I would hear what sounded like a turbo blow off valve opening and I would loose a couple pound of boost.
    Well, I figured it out. It was massive belt slip. The reason I did not catch it before is that the belt I was using had so much shellac on it that it did not make a sound when slipping or create any dust. After I got it off I saw it is sooooo shiney!! I am sure some of that shine is the slipping since I got the smaller pulley. So I got a Goodyear Gatorback belt to replace what I had. The belt I was using was the stock belt with 68000 miles on it. I know, I know, why didn't I change it when I did the pulley? Well I tried but got the wrong size. I got the 4080535 which was too small. I now have the 4080537 and it fit perfect.
    SO this post is 2 fold. One, replace your belt if you get a new pulley and two the correct size to use. With a 2.4 pulley you will need a 4080537 and with a 2.5 or 2.55 use a 4080540 belt. Stock is a 8PK1380 and Goodyear does not make a Gatorback in that size. Closest is a 4080545 and 1/4" longer than stock. It was costing me about 40rwhp when it slipped or about 50 horsepower at the crank! My midrange is crazy now and top end is ridiculous!! I will be changing to a 2.3 soon and when available I will team that with an oversized crank pulley (hint hint Tim). So if I just change the top pulley I should be able to use the 4080535 that is taking up room in my work area. Or with the combo I will have to figure it out.
    Disclaimer (For Boomys10): Individual results may varry
    creno is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V
    Jun 2011
    Ohio
    39
    38
    Re: Anyone with a smaller pulley PLEASE enter
    Good to know, I just re-used my stocker when I dropped pulleys. Does the 2.3 require any special machining to the snout? I machined mine down with the zzp rental tool and was wondering if the 2.3 would fit.
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    I have not tried it yet. Mine has been machined enough to use it but it was re-machined by Nathan at Smoothflow.
    AriGold. is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Jan 2011
    Tulsa, Oklahoma
    143
    I have Tims 2.4 Pulley and went back to the stock belt but added a bigger tensioner pulley. Gates 38052
    My phone went dead last night when I was posting PGA lol...
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Quote Originally Posted by arigold. View Post
    i went back to stock belt witg
    huh?
    boomys10 is offline Cadillac Owners Enthusiast
    Dec 2011
    Missouri
    31
    894
    From fairly extensive knowledge of this stuff now, everyone has different results with pulleys and belts as far as sliggage is concerned. I'm running the gatorback 540 on mine with the 2.55, which will be getting changed soon enough to the 2.3, BUT!!! You won't be able to use the 535 for the smaller upper AND bigger lower. You'll either need what you hav now, or a step larger. The lower is going to add a lot more than the upper loses. Just my two cents.
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Quote Originally Posted by boomys10 View Post
    There, I edited my OP just for you......... lol
    Jan 2011
    Tulsa, Oklahoma
    143
    Updated my post.. My phone went dead when I tried the first time.
    Dec 2011
    Missouri
    31
    894
    Rude.. lol. I was only saing that bc its true unfortuantely. No idea why my belt slip was so bad with stock belt and 2.55 but others hasn't been. Just want to let ppl know it may not all be equal.
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Exactly why I said to replace it if you change pulleys. lol.......
    1madstsv's Avatar
    1madstsv is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-V,10 escalade,80 sedan deville diesel 13 cts vagon
    Aug 2010
    York pa
    32
    1,599
    I make 20 psi and have never had belt slip. What are you all doing wrong. O wate never mind LOL.
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    Your a funny guy!
    Dec 2011
    Missouri
    31
    894
    im done pga. so over this relationship and it never started. lol. but in all seriousness, i think youll have an issue with the smaller upper and larger upper as far as belts are concerned. might be in the realm of idler pulley at that point.
  16. #14
    Carlosg's Avatar
    Carlosg is offline Cadillac Owners Fanatic
    Automobile(s): STs v
    Sep 2011
    San Antonio Texas
    38
    148
    Guys with smaller belt did y'all take off the tensioner and shave the small nip on the back. I try putting on the smaller belt could not get it. But with some help from a co worker was able to tighten my belt the one I had on and I am assuming I am max out the tensioner.
  17. #15
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    I'm still using the stock tensioner. Also a 2.3 is too small for the machined snout. I am not sure that it can safely be machined any smaller.
  18. Remove Advertisements
