Results 1 to 5 of 5
Thread: Remotes
    Apr 2011
    Minnesota
    278
    Remotes
    My car seems to be having trouble find my fobs. Is the battery dying on them?
    Oct 2005
    35
    Re: Remotes
    Probably. They are pretty cheap at a local chain drug store.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Re: Remotes
    Range on mine diminished till it would only work in the little slot in the center console. New battery fixed it.
  5. #4
    Apr 2011
    Minnesota
    278
    Good to know, I will have to go pick up a pack and change them both out.
    Another thing was when I used the second fob it changed all my programs on three radio. I knew it did it for both normally but this tine it never changed back. Any reason that it would do that?
  6. #5
    beyerch is offline Cadillac Owners Member
    Automobile(s): NONE
    Sep 2009
    71
    Re: Remotes
    In regards to limited range, probably weak battery in the remote. Secondary possibility is that something is wrong with one or more of the antennas in the car. If I recall correctly, there are at least 3 antennas. (L door, R door, Console) If you have a Tech II (or other soon to appear products), you will be able to see if the antennas are operating properly.
    In regards to radio settings, I believe you could have different personalization options for the remotes. Perhaps for one FOB, you don't change radio settings, but the other one does?
  • You may not post replies
