Broken Motor Mounts - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Cadillac STS-V Series Forum Discussion, Broken Motor Mounts in Cadillac V-Series Forums; Originally Posted by LITTLEELVISDAN I wish these would fit our cars. Anyone make poly replacements for ours? https://www.revshift.com/shop/polyur...llac-cts-v.php Your wish ...
  1. #16
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Re: Broken Motor Mounts
    Quote Originally Posted by LITTLEELVISDAN View Post
    Your wish has been granted.
    https://www.revshift.com/shop/polyur...llac-sts-v.php
    We will have better pictures up soon too.
  2. #17
    LITTLEELVISDAN's Avatar
    LITTLEELVISDAN is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V, 08 STS-V, 14 Raptor, 12 Camaro SS, 08 FJ
    Apr 2007
    Atlanta
    1,777
    For a daily driver that doesnt track, do you recommend soft or hard? And do either provide better, same, worse noise/vibration reduction over stock? After all it is the wifes car now. I need to purchase asap so what is the new price? :-)
    Too funny. I read prices not pictures. Oops. But the other questions still stand
  3. #18
    bobs-sts-v's Avatar
    bobs-sts-v is offline Cadillac Owners Fanatic
    Automobile(s): STS-V
    Feb 2007
    Naperville, IL
    393
    The harder the compound, the more engine noise that will be transmitted through them into the frame and therefore the cabin. My son works on high performance cars all the time, and most people are somewhat astonished by the increased noise and vibration from the poly motor mounts. While caddies have much better sound insulation than most, there will be an increase in noise and vibration by switching to poly. That is why most cars OEM mounts have the fluid in them - to dampen vibration and noise. If it is your wife's daily driver, I would go with the 80's instead of the 92's.
    Bob
  5. #19
    Apr 2007
    Atlanta
    1,777
    Since its my wifes daily driver I ordered stock rubber replacements. I would love to order Poly but dont want to take the chance she wouldnt like it. I know I would.
    The reason the quote is so high on Caddy doing the job is as follows.
    The part number for the rubber has a note that the bracket must be replaced at the same time and that both sides also have to be replaced at one time. That is why it calls for the sub frame to be lowered. I would immagine getting to the metal bracket on the motor would be a pain in the ass.
    But I ordered the rubber only and am going to give it a try in the driveway since I am already replacing the front bumper cover with the spare I have. How hard can the bottom and top nut on the bushing be to get to, right? Famous last words.
  6. #20
    AriGold. is offline Cadillac Owners Fanatic
    Jan 2011
    Tulsa, Oklahoma
    143
    I emailed RevShift 8 days ago asking if they would make these for our cars. They said no problem to send the measurements. I didn't get around to doing that because I got busy.. Glad someone did!! Just put in an order.
  7. #21
    PGA2B's Avatar
    PGA2B is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 OBM CTS-V Coupe
    Jun 2009
    USA
    2,659
    Make sure to update us on the labor involved and any pics if you can get some. Also the results.
  8. #22
    Apr 2007
    Atlanta
    1,777
    After reviewing the exploded diagram of our engine cradle i have decided there is not enough room to jack up the engine to get enough clearance to get the engine mount out. It is impossible to go from the top. So I have planned to put the car on jack stands to get it high enough for me to get under the car. The. I am goint to buy 4 engine cradle bolts that are 2 inches longer than stock. Then jack the engine to support the engine and tranny to keep exactly where it is. Remove front two cradle bolts and replace with longet ones leaving them 2 inches loose. Replace rear cradle bolts with new longer ones and leave 2 inches loose. The. Remove engine mount lower nuts and cradle should drop 2 inches to sit on the heads of the new cradle bolts. Remove top engine mount nut and remove old mount. Repeat on other side. Install new mounts and reverse process to put everything back together. Thats the plan at least. Well see how real life goes.
  9. #23
    Apr 2007
    Atlanta
    1,777
    Well its not 4 bolts. Suspension is connected to the subframs as is the power steering pump. I decided i am not going to try to do the mounts. Ill take it to a shop and have my mounts put in.
  10. #24
    PGA2B's Avatar
    Jun 2009
    USA
    2,659
    NOT good news Dan..... Let us know what they charge.
  11. #25
    Apr 2007
    Atlanta
    1,777
    Just got the car back.
    3 Things
    1) You know they are bad if you hear a couple of things. I heard what sounded like my blower snout clunking on cold shut down. ( moving car in driveway and turning right back off). I also felt a vibration in the steering wheel and shifter on idle and when down shifting.
    The big indication is if you start your car or shut if off you should NOT feel the engine.
    My new mounts makes the car feel like the engine isnt even running. I can't feel the engine start.
    2) power break the car with the hood up. If the motor rotates 1 inch or more, they are bad. let off the gas and you will feel a soft thunk as the engind sits back down.
    3) your transmission will shift soft/delayed/random early upshifts. hard launches will feel delayed and be very difficult to break the tires loose.
    100k miles on mine and now I can break the tires loose pretty easily in the rain. almost as easy as my Vette. I haven't been able to do this or worry about rain for a long time. Driving it home in the rain was quite fun today.
    To be honest I think my mounts were bad from the factory as I have never really felt mine was as powerful or quick as some other cars on this board. IT IS NOW!!!
  12. #26
    caddimoriarty's Avatar
    caddimoriarty is offline Cadillac Owners Member
    Automobile(s): 1998 sts..now a 2000 sts
    Apr 2010
    st clair missouri
    95
    They say $350 each total $700 and $900 for labor. Mechanic came out and said whole subframe has to be dropped.
    They say the motor mount is rubber and is fluid filled. Once the rubber cracks it leaks fluid. They say they saw both with a crack and evidence there was fluid leaking at some point in time.
    I am picking it up today without the mounts being replaced. Odd thing is that they are not concerned in the least that i am taking the car without replacing such a critical part.
    Wow!! Thats crazy expensive!! Im picking up a oem from mech for $60 a piece.
  13. Remove Advertisements
