Lane Departure and Blind Spot Install - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Cadillac STS-V Series Forum Discussion, Lane Departure and Blind Spot Install in Cadillac V-Series Forums; The Side Blind Zone Alert uses 2 small radar (of some kind) units mounted behind the rear bumper cover on ...
  1. #16
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,529
    Re: Lane Departure and Blind Spot Install
    The Side Blind Zone Alert uses 2 small radar (of some kind) units mounted behind the rear bumper cover on each side of the car covering a range of about 10 feet to either side of the car and from the mirrors back about 16 feet. The only camera system used on this car is mounted above the rearview mirror on the top of the windshield pointed forwards for lane departure warning.
    You will probably need new mirrors, each radar module, likely a new bumper cover that has mounting points for the modules, probably driver's door module and passenger door module, probably access to a tech 2 to reprogram the module, you might be required to have Navigation since the control for enable / disable is on the nav unit.
    If the side of your car is excessively dirty you will have reduced functionality. Both mirrors can be lit solid to indicate something in your blind spot, they only flash when a turn signal is on for the respective side of the car.
  2. #17
    cadillac 31 is offline Cadillac Owners Member
    Automobile(s): none
    Feb 2010
    43
    Quote Originally Posted by dl72 View Post
    How hard would it be, or even possible, to install Blind Spot and Lane Departure on an '06 STS-V? I think those are two good options to have. Any ideas/ Thanks.
    ....hey did you ever get an installation for blind spot and lane departure for your car im in the same position now i would like those added to my car
  3. #18
    dl72 is offline Cadillac Owners Fanatic
    Aug 2012
    343
    Quote Originally Posted by cadillac 31
    No, I didn't. Still looking at options.
